KiCad 5.1
You can also export KiCAD PCB into 3D in FreeCAD with KiCADStepUp plugin installed, it works great. The small PCB on top has been exported with KiCADStepUp
Now that’s amazingly cool. One of the things I’ve been toying with for power amps is doing a main board with all the hoofer power transistors, and a daughter board that sits on top with the low-current front end. I could create a footprint for the low-current bit, and export the whole PCB of it for the 3D render.
Mind blowing. I’d never contemplated boards as components.
It was, until you barged in.
Sorry Nigel, but you trying to compare your product with KiCad is laughable. I haven't tried to run your CAD system, but I can tell from the screen grabs on your webpage that it's firmly stuck in 1993. I used to run Protel AutoTrax and Schedit on DOS machines, and it looked remarkably similar. Big, chunky graphics that were optimised for EGA and VGA. Text based menus, because they're quick and easy to code. No fonts, so your silkscreens and schematics come out barely legible.
The screen-grabs you show for your product do nothing for it. The PCB you feature is the sort of thing that, had one of my techs produced it, I'd have spent some time with them teaching them how to design a decent board. Little things, like bevelling corners at 45 degrees (and sticking to 45 and 90 degree tracks unless there's a good reason not to), honouring minimum feature size for via annular rings, not having acute angles where tracks join. Cleaning up after you've done a copper pour so there's no mess.
And your schematics are barely readable. The whole idea of design is to make something that's manufacturable and maintainable, and those designs you show are neither.
KiCad, on the other hand, creates very manufacturable boards, and really beautiful schematics. I've attached a couple of screen-grabs from the board I'm currently working on. It's a dense little guy, with a whole lot of transistors, but that's how I like to do things. KiCad makes the job of producing a really clean schematic and layout straightforward.
I think you should stop bagging something where it's obvious you've got a clear financial motive to do so. We get you're bitter. Now rack off please.
That is exactly what I think - but did not write here
And by the way, this is a KiCAD thread so who is the spammer here?
You can even place an enclosure around your PCB - or at least a partially open enclosure, otherwise you won't see the inside of it 🙂 Did that with a custom fooprint which has only a crosshair on the fab layer and the step model of the enclosure attached to it. You can move the enclosure around with x/y/z offsets and rotation.
Very helpful for checking clearance issues, placement of knobs, connectors etc. on front plates and so forth.
Nigel, free software can exist together with commercial SW. Open/Libre Office is free, and MS sells still a lot of Office packages. Would I use KiCad professional, no. But for hobby it is great SW. Nigel, please don’t try to change this tread in a KiCad bashing tread. KiCad, for what it is intended, is quite good.
There is money to be made selling auxiliary software for KiCad.
For example, there are many users who would pay a reasonable price for a better autorouter than FreeRouting, better layer control, net priority and please not in Java.
I will second the request for a tutorial on the "replicate layout" plugin.
That's also a feature that I and many others would use every single day if it was integrated into KiCAD by default.
So often I'll have a board that has something like 10+ Versalink fiber inputs and almost as many outputs. A "replicate layout" function would make that much quicker to deal with. Normally what I do is copy, paste, then manually change the component designators. That's a lot of work for a complicated layout to be replicated.
People here would probably use it since we're typically dealing with stereo systems.
It´s all described at the link I posted.
Download the "replicate layout" folder and put in the "scripting" folder;
wherever this might be on your PC.
Then you are basically good to go.
(it´s now under tools/external plugins)
Place a hierarchical sheet in your schematic (something that is used multiple times). If you have a final version of that sheet, do the layout.
Then place another sheet in the schematics.
Annotate, update PCB and do as described in that link above.
Haven´t played around with it extensively but started a design for a discrete crossover which is basically a little buffer with some passives around, copied about a dozen times.
It works really nice. Copies all the tracks and vias.
Here’s a cool one. There’s a tool for KiCAD that does interactive assembly placement. Just run it from the PCB window and it creates a HTML file with all your components, ordered by type. So then when you hover over a component in the list, it highlights all the spots on the PCB where it goes, top and bottom.
It makes assembly too easy, I reckon, especially where your boards are dense enough that you can’t fit the designators into the silkscreen.
And when you’re assembling, you don’t even need KiCad. Just the htm file and a browser.
