Keantoken's CFP cap multiplier
Well it could be square, long and thin, wide and flat, etc. So far I'm tending towards a square layout because that is best electrically, with the TO220 on the edge so it can be bent under the board for direct mount to heatsink or chassis, or left standing with a floating heatsink, or soldered flat with the board.
Here it is, minus two resistors I had to order (my half watts are too big)
TNT
Joined 2003
Ahhrg - I think it is OK actually - thanks!
So the diode is connected to the 1930 legs rigth behind (red rings). The 337 is connected to the 1930 as the red line. OK?
