Some links on their website aren't working right, and so, can't access directly to the page of the sub120_vHP-F. But the page exist, modifying the adress directly in address bar copying their website naming logic, i found it, and it's IMPRESSIVE :
Sub120_vHP-F | .Kartesian
LOOK AT BL AND KMS CURVES vs Excursion !!!! Those are straight on +/- 5mm excursion !!!
And look on the datasheet, the frequency response !!! (datasheets are on distributor site only)
https://en.toutlehautparleur.com/media/catalog/product/datasheet/kartesian/SUB120_VHP-F-8.pdf
74,88 € is fair i think at this level.
purifi
look at this
PTT6.5W08-01 - PURIFI
costly, but the best measure i've seen for an 6.5 pouce, mayby the very best 6.5-7 mid woofer in the world
the klippl measure is exceptional
at their price the kartezian seems to be very good
look at this
Received ! Wom120_vMS and CMP_25vHP
I plan to compare the little CMP_25vHP to ~same size (plastic apart) but really PA oriented comp oberton HL50 that seemed be interesting tro try with a fair amount of EQ from it prodance measurement
: https://www.prodance.cz/data/attachments/mereni_Oberton_HL50.pdf
Fourth picture is to show the little chamfering on the top plate and generous magnet gap for such a low qts motor.
The little horn is labelled zongson that is from what i can find a german company...weird...
There's a clear misalignement between dome and phase plug (it's not a effect from photo orientation). And once back screws are removed, the motor is glued to the horn part, so i cannot realign it without removing glue
Good point is that there's huge amount of thermal paste between the back "radiator" and the motor.
I'll try realignement once measured first.
Even if I'm really curious, I won't have time to measure them before 1-2 weeks.
This is not their small sub, it only the Wom120_vMS. I'll use it in place of a tang band w4-1320si, that is really nice, but got directivity issues loaded in horn due to it phase plug. The revert surround on the kartesian might help to minimize throat junction with horn.
Yes, France, to France. On TLHP facebook, they posted that they received them yesterday Facebook and so they must have immediatly shipped them to me.PapaSteak, you have recieved your package at Limoges ??? Forwarding to hear you after you fire up them... (well the fun is I received today some SB Acoustics...)
The woof looks impressive ! wow...
Me it was the Monsieur of Compagnie acoustic of Belgium as THLP had not the 23cm SB Acoustics I wanted in stock. Very serious guy, drivers received by DLPD services, the same that THLP : fast & accurate one week after the click, drivers sent from Denmark directly not from Belgium! THLP are faster than Amazon I experienced when the item is in stock... They don't often answer to the mails but they ship faster than Lucky-Luck !
TLHP have stunning fast shipping , order before 16H ( 4 PM ) , delivery the next day
Interesting - thanks for the link!
I'm considering to build a stereo set of active 3 way speakers. Wonder whether one of these coax types and the 10 inch woofer might fit.
- Kartesian Acoustic
