Kartesian Acoustic
Some links on their website aren't working right, and so, can't access directly to the page of the sub120_vHP-F. But the page exist, modifying the adress directly in address bar copying their website naming logic, i found it, and it's IMPRESSIVE :
Sub120_vHP-F | .Kartesian
LOOK AT BL AND KMS CURVES vs Excursion !!!! Those are straight on +/- 5mm excursion !!!
And look on the datasheet, the frequency response !!! (datasheets are on distributor site only)
https://en.toutlehautparleur.com/media/catalog/product/datasheet/kartesian/SUB120_VHP-F-8.pdf
74,88 € is fair i think at this level.
Now all references are in stock !
Received ! Wom120_vMS and CMP_25vHP
I plan to compare the little CMP_25vHP to ~same size (plastic apart) but really PA oriented comp oberton HL50 that seemed be interesting tro try with a fair amount of EQ from it prodance measurement
: https://www.prodance.cz/data/attachments/mereni_Oberton_HL50.pdf
Fourth picture is to show the little chamfering on the top plate and generous magnet gap for such a low qts motor.
The little horn is labelled zongson that is from what i can find a german company...weird...
There's a clear misalignement between dome and phase plug (it's not a effect from photo orientation). And once back screws are removed, the motor is glued to the horn part, so i cannot realign it without removing glue :(
Good point is that there's huge amount of thermal paste between the back "radiator" and the motor.
I'll try realignement once measured first.
Even if I'm really curious, I won't have time to measure them before 1-2 weeks.
This is not their small sub, it only the Wom120_vMS. I'll use it in place of a tang band w4-1320si, that is really nice, but got directivity issues loaded in horn due to it phase plug. The revert surround on the kartesian might help to minimize throat junction with horn.
Disabled Account
Joined 2019
Me it was the Monsieur of Compagnie acoustic of Belgium as THLP had not the 23cm SB Acoustics I wanted in stock. Very serious guy, drivers received by DLPD services, the same that THLP : fast & accurate one week after the click, drivers sent from Denmark directly not from Belgium! THLP are faster than Amazon I experienced when the item is in stock... They don't often answer to the mails but they ship faster than Lucky-Luck !
TLHP have stunning fast shipping , order before 16H ( 4 PM ) , delivery the next day :D
