John Curl's Blowtorch preamplifier
Where does the 3'rd harmonic come from a simple differential pair? I am not talking about someone's compromised circuit, just a simple differential pair. It has to have some 3'rd harmonic, however 2'd harmonic is an artifact of circuit imperfection in some way. Perhaps matching, thermal offset, etc.
Walt helps:
john curl said:
Scott, anyone can do it graphically, but can you do it mathematically?
Let's see it for FET's, closed form now, no cheating. The Taylor series expansion for long tailed pairs has been published ad nauseum. From Walt's graph there I'd guess we would start with AX - BX**3 and go from there. This is sort of intuitive stuff, take a square law non-linearity and flip it on the other side of the axis and take the Taylor series. And please, I don't mean to insult anyone who has to think about it for a while, that's what learning is all about.
Here's my point.
It has previously stated or at least implied in this forum that
degeneration as local feedback creates higher order harmonics
that did not exist in the undegenerated state.
A little thought experiment convinced me that this cannot be
generally true. We know that the harmonic content of the
amplified output reflects variations in gain due to the fluctuations
of current through the device and also voltage across the device.
So consider the example a JFET operated Common Source. We
can freeze the Vds by cascoding it and measure the distortion
for a given output current swing. When we compare the
harmonics for the undegenerated case with the degenerated
case (Source resistor), we see that the distortion remains the
same for the same current swing. In the degenerated case of
course, the input voltage is much higher, and the distortion is
lower by comparison to it, but the ratio of the harmonics remains
the same.
Not content with that, I built up the circuit which performed this
experiment and measured the distortion and its spectral content
and confirmed that this was the case to reasonable accuracy.
I also noted that if I did not hold the Vds constant, but let it
alter out-of-phase with the input signal, there was suppression
of 2nd harmonic and an increase in 3rd. This latter was true for
both Common Source and Common Drain examples, but if you
think about it, this voltage variation acts more or less like loop
feedback, and simply confirms what we already know about
negative feedback loops.
I have to conclude that there is in fact a real distinction between
the performance degenerative local feedback and loop feedback.
Nelson Pass said:
Here's my point.
Baxandall and Cherry were only talking about global feedback I think, as was I, sorry for any misunderstanding. Baxandall IIRC only presented measurements (and shunned too much math) on a real JFET amplifier which did show the effect. I'm sure Cherry did somewhat the opposite.
