JLH 10 Watt class A amplifier
Regards to Somerset; born there early 60 yrs ago and was visiting last November.......did you know JLH lived in Taunton for many years?
Yes, evidence points to JLH having lived in Taunton; most of his WW letters are signed off as JLH, Taunton, Somerset.
I'm sure I read somewhere his house was called 'Robins' (Robin Hood, geddit)
There really was no-one quite like him, or will ever be again.
Reactions: The Prof
Re high current at turn on. The original article and the subsequent "WW" 15-20 watt Class AB circuit both had largish thermistors in the AC line to the primary. They were CZ numbers I think. That was for relatively small PS caps. More important as of late with much higher values being used. Jung also published a circuit with a timer to limit voltage at turn on. It was "AUDIO" (US) from way back (80's) but there must be other diy "soft start" schematics around.
Hellow Everybody,
My first post after joining DIY forum. Just completed reading all 187 pages (1863 posts) of this thread.
Built a JLLH way back in the 70s, with 1711 & 3055s, Home wound transformer, Home made heat sinks from a design from Mullard, Burrows preamp. Did not touch a soldering iron for 30 years.
Time to start dedusting the old amp and getting a new soldering iron!
--gannaji.
Welcome Gannaji,
Will look forward to reading your exploits if you decide to construct a JLH.
All people on this thread seem friendly and helpful and have given me lots of advice. Am in the process of building a 20 watt version and if I knew how to post some pictures I would ( help )
Go on Gannaji, get that soldering iron heated up.
Alan
Alan,
You need to click 'Go Advanced' at the bottom of this page and then click 'manage attachments' to open a pop up window where you can add pics. There is a limit on the size of the file.
Gannaji, go on and show us pics!
Old JLLH photos
Thank you all!
The first photo!
Hope it comes out alright!
Old JLLH photos
Now that I could successfully upload the first photo, here are three more.
For some boring details:
Myself and my friend (Bachelor at that time) did this as a joint venture. He brought all the materials from Delhi. We assembled as follows. Taken paper based phenolic board, (6 nos), stick graph paper to them, drew the circuit diagram, drilled the holes and assembled exactly as per the diagram lay out. Each channel consists of one preamp board (Burrows), one buffer cum low-high pass board and one Power amplifier board. All the six boards were spreadout on his dining table along with four heat sinks, connected to Two loud speakers, known as Mellow Monsters, constructed from an American DIY magazine. The signal source was a Philips record player with ceramic pickup. This was like that for a few years. In 80, my friend emigrated to US and the boards and Loudspeakers were left with me. Then I assembled the whole thing into a wooden Box and used it for around 8 years.
The circuit used was the one given by JLLH in a letter to use 3055 and 1711 as VAS or phase splitter.There used to be a slight switch on thump. There was also slight hum when heard with ears within 12 inches of the loud speakers. Else, the whole system was very enjoyable.
--gannaji
Hi everyone, i have started to construct the power supply ( rightly or wrongly, comments please ) Here is a rundown of progress so far.
2 x 300VA torroids suspended in rubber bushes in an aluminium housing.
2 x 25 Amp bridges for each torroid.
4 x 10,000 uF electrolitics.
4 x 1 OHM 25 watt resistors.
4 x 100,000 uF electrolitics
0.1uf bypass caps.
Fuses on primary of torroids
Fuses before amplifiers
This is all housed in a chassis made of 10mm aluminium plate, 400mm long x 250mm wide x 150mm high. heatsinks will be mounted along both long sides ( heatsinks are 400x 150x40 ).
I will try to post some pics of the work so far, have not posted pics before so appologies if I get it wrong.
Alan
I saw this too, but looks like the top toroid is bolted to top plate, while bottom toroid is bolted to bottom plate. There should not be single bolt going through both toroids...or else you will have shorted turn...
EDIT - or the washers...
Hi all, thanks for looking at the pictures. The torroids are suspended by 8mm threaded rod. The rod passes through both and is well insulated top and bottom from the chassis to avoid shorted turn problem. I have mounted the torroids like this to prevent any noise or vibration from them. Seems to work OK as I can put my ear really close when they are on and can't hear a thing.
Will post some more pics as I progress, but it may be a while.
Alan
