I know I still would like to buy the lowest noise jfets for the application, I will use them at various circuit not just for this place, and some will be amplifiers.
Just to make sure I understand, will I get the same noise with all jfets, in this application ?
Will it be buried under the other noise, or will it add up, noticeable or not ?
By the way the signal will be amplifier after.
Thank you very much this is gold, that is what I want to learn.
J113 to92 look like the perfect price/performance/availability I will start with this one.
I am looking between the 113 and for buffer alone these :
- 2N4117/A, 2N4118/A,2N4119/A
https://www.mouser.fr/datasheet/2/676/jfet-2n4117-2n4118-2n4119a-interfet.r00-1649084.pdf
- J210, J211, J212
https://www.mouser.fr/datasheet/2/676/jfet-j210-j211-j212-interfet.r00-1649154.pdf
I don't want to go look for discontinued devices.
1mA to 2mA seems to be a universal sweet spot even for tubes !
- J210, J211, J212
Went to Mouser and ordered a fistful of ON J113 Jfets. According to the ON product data sheet the J113 has a min of 2ma Idss, no max is given. According to the Mouser page the J113 Idss range is 2ma to 9ma. I hope that this range is not to far from the truth.
The J113 are cheep and easy to get, so we will test them first.
Thanks DT
Thanks DT
I'm afraid it might be. The ones I got from mouser some time back had much higher IDSSAccording to the Mouser page the J113 Idss range is 2ma to 9ma. I hope that this range is not to far from the truth.
Agreed, more like 15–30mA IDSS spread. (on-semi through hole j113).I'm afraid it might be. The ones I got from mouser some time back had much higher IDSS
DS minimum values are very far from actual part's values.
There is huge difference between DS and measurements of 2sk117,
Post in thread 'JFET’s J113, 2SK170, 2N5457 and others' https://www.diyaudio.com/community/threads/jfets-j113-2sk170-2n5457-and-others.340796/post-5870416
Few years ago i buyed 500 pcs.Went to Mouser and ordered a fistful of ON J113 Jfets. According to the ON product data sheet the J113 has a min of 2ma Idss, no max is given. According to the Mouser page the J113 Idss range is 2ma to 9ma. I hope that this range is not to far from the truth.
Thanks DT
53 pcs 9-13mA Idss
182 pcs 13-17 mA Idss
rest 17-26 mA idss
Measured at 15vds, same as Vds at datasheet.
Please compare your batch. Maybe there is difference related to Idss spread.
- JFET’s J113, 2SK170, 2N5457 and others
