JfetBOZ mods
I usually measure Vi and Vo as shown for unbalanced-in and balanced-out at different frequencies:
V gain = Vo/Vi x 2
Then, I could reasonably estimate what is the V-gain at each frequency
and how the gain curve varies along the frequency axis.
:darkside:
Hmm . . . the forum refuses attachement of my sketch having size of 37kB. Why . . . ? Because there are too many OTs?
V gain = Vo/Vi x 2
:darkside:
Hmm . . . the forum refuses attachment of my sketch having size of 37kB. Why . . . ? Because there are too many OTs?
I've noticed that PNG graphics can be physically larger than the other formats. Try that.
What if you have balanced in and single-ended out?
I'm trying again . . .
I usually estimate the V-gain by measuring Vi and Vo as shown.
Unbalanced-out: V gain = Vo/Vi
Balanced-out: V gain = (Vo/Vi) x 2
It does not matter of unbalance-in or balanced-in.
:darkside:
At least... it works.
Thx for this very nice sketch.
All this details about testing procedure, (even where placing probes, where not, etc).. are very usefull for people like me,
since I never managed to use properly my recently ebayed scope...
It will encourage me to give other try
Manu
I couldn't figure out how my little gain-stage could put out so little voltage. It just didn't make sense. So, I connected my VOM to my gain-stage. I set the VOM reading to AC since the gain-stage was receiving a 1000hz signal:
input: 0.375v
output: 7.8v
My scope reads increments differently than I thought; each little mark means a division, not just the large grid lines. It doesn't even seem to matter that the probe is 10x, it still matches the VOM. A bit confusing......
My gain is high: 20.8
BTW, the gain-stage begins to clip when I ask it to deliver more than 7.8 volts.
Does it seem that I'm on the correct path, or have I deluded myself? 😀
Wouldn't be the first time.......
Edit: I connected my VOM just like the last pic I submitted, using Babowana's drawing.
carpenter said:
It makes a huge difference, with my system, where I place the input probes. The input voltage is double when I probe the + and - inputs together verses + and ground.
We are going to check V-gain.
It doesn't matter whether we use balanced or unbalanced input.
The unbalanced output devided by the input (balanced or
unbalanced) gives us the v-gain.
Hope you will check also at lower frequencies . . .
:darkside:
carpenter said:
As per my last post, does my measuring process seem correct
with the volt/ohm meter?
I guess your scope has eight divisions vertically.
Just adjust for both channels to have the same volts/div setting.
And, trust the results coming from the equipment.
For example, If the volts/div setting is 5 volts,
then each of the eight vertical divisions represents 5 volts.
Meanwhile, if you use different v/d settings between two channels,
then put out your HP calculator to practice math with
the different scaling factors.
Oh . . . I’m assuming that you set the both probes to 10X.
Otherwise, you need another practice of the math with
:darkside:
