JC-80 eBay PCBs & Power Train
I have both the JC-80 and a balanced DCB1 and they are both extremely good in their respective ways. Keep in mind that the DCB1 has a gain of 1 and my JC-80 is set to 7.5 of gain. I would say that the stage is a little wider on the DCB1 but my preference is leaning toward the JC-80 but I do use both and like them both very much. I won't go into details but it is my personal taste.
Do
I have just received next PCBs from manufacturer.
HI Guys can you help please if I use the BL version of these FETS will I have to make any component changes around them? I'm using the "E" bay Jims board schematic.
Actually you can send an email to Jims Audio, I believe he has some used pulls which are genuine but will cost you about 35$-40$ a pair. It is V grade parts.
It is just the Idss that is higher if I'm not mistaking, V grade is in the range of 12-20?? If you take the highest range of BL I'm jusre it would work. You can use 2SK170/J74 to replace them but need a really tight match and something to bind them together for thermal coupling.
Ciao!
Do
