Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
lowest possible, if your sources are having enough cojones
25K is safe bet
shunt resistor from gate of JFet buffer is defining input impedance
keep it at least 10 times higher than value of volume pot
or even higher
no problem even with 470K .......... it's there practically just in case of pot wiper loosing contact, once in future
Reactions: glenv6
Tomorrow my balanced Iron Pre chassis should be here, and I can start on that. To that end, I assume a reread of this thread and Iron pre build guide is in order.
I have built two Iron Pres, one was a beta build, second was with modushop chassis, twister and all. I sort of glossed over info on balanced versions.
Any suggestions to avoid pitfalls with this similar, but a touch different balanced Iron Pre? Looks pretty straight forward.
Russellc
^ You'll be totally fine. Biggest change is setting current through buffer (one more set of pots per board to fiddle and twiddle).
Other than that... build two boards and wire 'em up. 🙂 Enjoy!
Edited to add - OH! I can't remember what version you built previously - Don't forget the jumper (J1 or J5.... can't remember) if you're not using logic controls. That's the #1 issue I see with reports of "everything looks good, but I get no sound". 2nd to that is forgetting to install jumper caps after nulling offset. Don't mix up the TO-92s...
Another Iron Pre is singing! Wow this is truly an awesome gift, huge shoutout and thank you to Zen Mod, ItsAllInMy Head, Mr Pass and all the helpful people on this forum! It is dead quiet, but the sound it produces is clean, detailed, and very engaging. I am somewhat new to diy audio, the build guide and the threads were extremely helpful. I learned a lot on this build, a lot of firsts for me.
Thank again for this wonderful gift!
How do you like those nx-studios?
Not a kit, but I can't help but share me enthusiasm for this wonderful preamp.
Built from earlier boards from Jim. Cutting and welding involved of a clapped out crest power amp chassis. AC routed through 12 gage square tube. That's what I had.... Ultra isolated power supply with lots of steel. Hifi collective shunt attenuator really was an incredible shift in SQ. Uncanny. Aside from iron, is there a better circuit to attenuate? 2 resistors. Well 4 total bal. Zfoils in the right places. Perfect.
I completed my boards and was toning things out before firing up the Iron Pre for the first time when I noticed both of the Out pads, plus and minus, are going to ground. This is the situation on both of my boards, jumpers on and jumpers off. I am not finding any solder bridges or misplaced parts on my boards. I can’t tell from the schematic or from the “eagle” board traces pict if this is the normal situation when the boards are powered off.
BTW, I noticed a lot of builders leaving the snubbers out on these later boards. I Quasimodo’d my Antek AN0218 with the standard C values and found R to be 34.5 ohms.
Thanks in advance for any guidance provided.
-Glen
