Iron Pre Essentials Kits For The DIYA Store - Register Your Interest
Hello freebee,
answering your post # 1298:
those are Vishay/Spectrol precision pots (5 %), 20 kOhm, 10-turn (not for the lazy boys), linear taper. I like them. I also like the Bourns.
Cheers
Dirk
Reactions: freebee
If I listen to acoustic music, especially with stringinstruments (guitar) or to a piano (which is in my opinion often a challenge for amps),
the Iron Pre plays very exact and detailed. No harshness. High tones from a piano sound like a piano.
If a string swings out long like from a long guitar tone - great!
A current favorite of mine for all the reasons you mention
Duo 2 is as good…maybe better
Reactions: scranton
I emerge from my listening cocoon for coffee, food, and to report back:
On Friday afternoon I finally received my delivery of D-series RCA jacks and wired up single-ended output of my Balanced Iron Pre. Now don't get me wrong: the reason I built the Balanced IP was that I have a pair of Classic Aleph 60 monoblocks where I've set up switchable SE or balanced inputs, and the last week has been fun with the IP driving those balanced inputs. The balanced input really does reduce the noise. I can have the volume up, nothing playing, put my ear on the horn-tweeter and ...nothing. You can't tell the amp is even on. Then you press play...
But then I switched to the SE input of the Alephs driven by the IP's SE output. Yes, you can now tell the amp is on by putting your ear to the tweeter. But it is, relatively speaking, still so quiet. Then you press play... and the speakers start throwing auras into the room. The top end is so smooth and open; the recording venue's sounds decay and bounce around; all the audio-review clichés become reality (palpable presence, bloom, whatevs). Friday night was spent in the zone, like when your golf swing just clicks and suddenly it's long straight drives into the fairway and smooth irons to the green. Putt, putt, par. I just sat there trying to read a book yet following sonic threads in and out of the music. My theory about the balanced is that the common-mode rejection eats into the sonic presentation. That could be utter bullocks and ignorance, but my other experience with a balanced pre (a Classe Thirty) is the same: the signal is trying to break through; can't breathe.
Saturday morning I moved the M2X (Ishikawa front end card) into the room. Now here's an amp I love. It sings, it is beauty, it is the very definition of musical, of space, of timbre, of lilies. But it can't control the bass. And I like deep and tight bass. Not deep and boomy, not out of control, but articulated. Not loud bass, but "just right" bass. Synthesizers and real drum kicks. Thunder. Something the Alephs just dominate with. Until now. The Iron Pre SE tells the M2X what to do down there. And with that foundation solid, the rest of the M2x does what it does best, and sings. Curtains are drawn back, sun shines through, accents are identified, off key vocals have nowhere to hide, and you can see George Harrison grin as he sings "no one alaihhhhhhrr-tedyieux" on My Guitar Gently Weeps from the Beatles/Cirque de Soleil "Love" album. A minute later and Metallica's Master of Puppets' screaming Marshalls, toms, and cymbal crashes are tight, powerful. Metallica and M2X were not meant for each other in the past. But they're headbanging together now. Iron Pre SE pulled a lot out of the M2x that had been hidden.
And that's why we build these things.
I really need to work on the case of this thing instead of leaving it open and exposed on a carboard box in the listening room with wires running everywhere. But there's too much listening to do. Why not? It's been raining here in Maine for the last week (the heat came on this week) and I'm in a honeymoon mood.
Are there any rules regarding XLR chassis mount connectors if you use male or female?
My DAC has XLR-male out. Would it be natural also to use XLR-male in on IronPre BAL version?
What is the common standard?
I will order some Neutrik RCA chassis mount connectors for Iron SE and to prepare for a future BAL version I would like to order some Neutrik XLR connectors also.
think Cold and Hot, same logic as mains connectors
input XLR connector's contacts needs to be protected from fingers, so female .......same as live side of mains connectors need to protect fingers touching contacts (to avoid yadayada!!! )
what's left for output XLR are other ones
Real Sissies are using Square Law OS M2
:devilr:
My DAC does too. Another reason I built the Balanced IP.
Most XLR cables are male at one end, female at the other. So male connector out of DAC leads to male end of cable going into female input on pre; male output of pre leads to male end of cable going into female input on amp.
Standard pinouts are
1 = ground
2 = positive
3 = negative (balanced? signal)
Reactions: MEPER
help me understand how this is achieved...
35 years of effort come together for about 4-5 holes. What an ROI! Lessons-wise, YouTuber Shawn Clement helped me make the mental understanding leap of what the golf swing really is.
Whereas my oldest son has a handicap of about 2 better than par, and wins tournaments, his 5'9 meaty frame smashing 300+ yard drives, etc. It's fun to witness a real golfer.
Reactions: ItsAllInMyHead
which reminds me of perfect DIYer solution - leave that one singing on the cardboard, while fully assembling another one ........ that way no pause in ironpresssnessss, doubledouble pleasure
:clown:
Checked out his page. I dig his style. Thanks!
Watching 'real' golfers play is amazing. Distance is one thing, but to me, it's more remarkable how they can control the flight. Shot tracer on TV has helped a ton, but in person... wow! My favorite is college events or high-level amateur. Senior Tour events are nice too. We get the 3M event nearby, and we get great events at Hazeltine, but I liked it better when the Seniors/Champions Tour or the LPGA passed through. The US Amateur at Hazeltine was one of my all-time favorite events. Big Tour events are not my favorite... They're usually insanely crowded, and I have a 5' 7" <cough> 'meaty' frame <cough>, so seeing over everyone is not in my cards. The main reason I like amateur events, is that you can typically walk the fairways with the players and get close enough to hear their discussions with their caddies. Most of them would never make the cut at a Tour event, but it's still awfully impressive.
On a more realistic level... I had a match play event the other day, and my friend brought his son out with him. He'd just finished up his freshman year in college and plays to a +1. That power / speed is massive. It makes my back hurt just thinking about it.
Back on topic... I'll take golf soundtracks for 2000, Aleks. 😉
