Oleg,
While front panel require some exact dimensions to accommodate display, infrared remote and bluetooth, back panel is up to your final design, power plug and RCA connectors you may want to use.
Even so, all I can provide are freecad files not autodesk.
Regards,
Tibi
Regards,
Tibi
Hi Tibi,
Sorry I think I did not express myself correctly.
I mean the back of the front panel.
You are right the back panel is easy to build on your own and I did it already.
I was just finishing the front pa El itself based on your dwg and thought it could be useful to have the back side of the front panel in dwg as well
I'll get more used to free cad files than))
Sent from my ONE A2003 using Tapatalk
Oleg,
Native freecad file, which I already attached, offer to you possibility to see drawing in 3D view, from any angle. Later you may export dwg files, but in 2D.
Freecad is free and the only effort is to install this to your computer.
Regards,
Tibi
Regards,
Tibi
You are right tip b. The only problem I had unrelated to free cad my pc is spoiled. So will need to get a new one and it solves it. Thanks again)
Based on previous information some months ago I had purchased a 6 volt transformer to power the Maya. Now that I've received the Maya I see that it is marked 9 volts AC. OK so I hook it up to a variac set for 9 volts. The relays buzz pretty bad. Moving the voltage up to 12 volts AC quiets them down and it seems to work better.
So I wonder if the Maya be run at 12 volts AC without problem?
For Maya you need a 6Vac trafo @ min 2A.
At 9Vac and 12Vac power dissipated by regulator is too high.
If you want to run Maya at 12Vac, you need to de-solder the regulator and move it to a heatsink.
Regards,
Tibi
Regards,
Tibi
At 6 volts AC the relays buzz. Is that normal? Not only is it annoying but it may shorten the life of the relays.
It's not normal. Please change C8 and C9 to 1000uF as Danzup suggest in this post.
http://www.diyaudio.com/forums/grou...aya-r2r-volume-controller-11.html#post4621326
Regards,
Tibi
Regards,
Tibi
I would like to remind that this is a DIY product. We are developing and improve this together with you, therefore any suggestion you may have will be carefully reviewed and implemented. As in any diyaudio GB, you get this product at a lower price, but with best support we can offer. It may have software bugs, which we already corrected, or hardware mistakes, like C8 and C9.
We are here for DIY and hope you too.
Regards,
Tibi
Regards,
Tibi
Like Tibi say upgrade those 2 capacitors and everything will be OK.
About C8 - C9 capacitors
Hi all ,
this is a recommendation from me (and have been tested) :
if you want to go for the best I will replace C9 with a 2200uF / 25V capacitor , but you must first test if the footprint is OK and if that capacitor fits OK there on board first of all.
Never the less a minimum of 1000uF /16V is still recommended .
Hi all ,
My pre-amp is under structure of on-board input selectors by relay switches which controlled by an Alps mechanical selectors, and there is a straight line indicator area of 5 LED to indicate which input channel is running. As the LED indicators area occupied large part of the front panel, it is not possible to modify front panel with a window to install the display screen as well as new holes for push buttons.
For the above mentioned reason, I am planning to use a smaller box only for display screen/logic board of the kit, and put this smaller box on top of my pre-amp. I need to extend two cables for this configuration, one is connection between logic board and volume control/input selector board, the other is connection between logic board and volume control decoder.
My question is should I arrange these two cables away from signal path? and what location is better (for example: near AC power code) if I want to build one or two connectors on the back panel for connecting the extension cables? what type of connector should I use to keep connection good without interference?
David,
Entire audio thing is happen on relay boards. Even more analog signal path is completely isolated from digital.
You may extend cables as you wish. Let's say up to 1m is OK.
Keep relay boards as far as possible from power transformer (to reduce noise) and amplifier output (to avoid input-output oscillation).
Best regards,
Tibi
Best regards,
Tibi
David,
Best regards,
Tibi
Tibi, thank you very much.
David
Yesterday I installed 2200uF/25v caps for C8 and C9. All is silent now except for the lovely sound of clicking relays!
Zettler are noisier but switch three times faster (on-2ms/off-1ms) than Takamisawa (on-6ms/off-4ms) and have more than 2 times lower contact resistance.
Regards,
Tibi
Regards,
Tibi
https://drive.google.com/file/d/0B8Z0wE1TFDZ0RjFqOGpOczZLN2c/view?usp=sharing
what is the green connector for?
Fuse. Use one adequate for your pre/amplifier.
Regards,
Tibi
Tibi,
David
Tibi,
Can you explain the functions of the speaker/Power and soft start board?
I measure continuity between the in-out speaker connections when the controller is in standby and no continuity when the controller is on. I expected just the opposite.
Also how does the soft start work? There is continuity when off but not when on. Do you have a circuit diagram?
Thanks, Mike
Thanks, Mike
- Group Buys
- Interest check on Vicol Audio Maya R2R Volume controller
