Improving a cheap chinese PCM1794 DAC
Because some years ago i also tested a dac kit with PCM1794 and i like it a lot the sound of this chip i was thinking to come back and give it a try again.
I remember it sounded very good with Lm49713 in I/V position but a bit hard to tame them as they are very fast opamps.
That's why i want to ask @pachy : why did you choose to introduce between dac board and Raspberry that Jlsounds USB to I2S receiver? You could feed the dac with I2S directly from Raspberry.
JLsounds XMOS provides galvanic isolation which eliminates common noise which is produced by the Raspberry Pi or its PSU and even more important is that it hosts oscillators for reclock of the signal which results in significantly reduced jitter compared to the Raspberry Pi's own I2S which is just not good enough for high quality audio.
If you are still not convinced see a more detailed explanation here: The Raspberry Pi: Audio out through I2S | Dimdim's Blog
@pachy,
which Input and output signal to / from Jlsounds are you using
I am using the S/PDIF output of JLSounds because I wanted to retain digital input switching capability by the AK4113 on the PCM1794 board, which switches between the stock s/pdif coax connector which I relocated on the rear panel of my enclosure, stock toslink (also relocated) and the s/pdif from the JLSounds board. You can find the hidden third S/PDIF input on the first two pins on the Amanero header of the PCM1794 board.
What do you mean by the "right" transformer? Power supply transformer is 2x15VAC + 2x9VAC R-core transformer from Audiophonics(or ebay, aliexpress). For the Raspberry and JLSounds XMOS I have a separate 2x6VAC transformer before linear regulators, one winding is used for the Pi and the other one supplies the part of the JLSounds (with reclock / after galvanic isolation), the USB part of JLSounds is supplied from the USB connection to the Raspberry.
@pachy,
thanks for your help.
Ordered one (same as yours).
If all arrived, i will done some measurements (missing in this thread!) and post the results here.
edit:
Done some simulations in LTSpice (I/V & LPF)
have a nice day!
Some simulation:
My DAC arrived from China.
First impressions, the AD827 gone really hot, changed for safety reason to 5532.
Sadly, the display does not shows any information.....
All voltages are correct.
Except the display the DAC is working.
If i have more time i will begin to measure the device.
I don't know if OP is still modifying his or her PCM1794 dac. But the mod that did the most was the CCS mod on pin 'something or the other' (forgot the number) that I got from the DDDac thread. It's a -40mA CCS that's there in place of the resistor to ground if I can remember correctly. I made it on a piece of protoboard. It's just a trimmer, a transistor and a resister or 2.
Hi .
It took some time and some small progress to make a dual system DAC with the use of PCM 1794 and vacuum tubes.
