I don't think they're complaining really. In fact they admit the ones they made are similar to each other...
Now really, i removed my layout, and both of guys compare my board with own boards claiming i copy design ...
What ever, i make new layout, and will go for fabrication !
Will post gerbers for anyone who want to make one ...
END of story !
For future reference, I make a point of retaining copyright, and I never
accept money for submissions.
That said, people need to buy a subscription to AX. It's the least they
can do for the efforts made for their benefit.
Hi Mr. Pass !
I make a logo for Preamlifier i am about to build and want to ask you about permission to use this logo !
In name ImPASSe i use sale font you use for your logo !
Thanx!
Since Nelson Pass had nothing to do with the preamp design it might be a bit too much..
The only connection with Pass designs is that Stuart Yaniger designed it to work with the Pass F-4 amp I built. 😉
On the boards you posted it looks more subtle though.
I send him email and ask him, if he is OK, will go for it, if no, will just change font, easy like that ... 🙂
Aleph 4 has even more gain than the F5...
I know, I'm only testing it with the F5.
are you selling boards?
No, i am not, but if board come out OK, will be for sale - not by me, but someone else, will let you know ...
If I have a chance to buy all of the parts, is there a good build guide? I realize it may be somewhere in this thread but 87 pages... maybe someone knows the answer.
I think Jack Walton at tech-diy was selling boards that he designed. If someone wants to give a PCB design to diyAudio's store to sell and there's demand for it, that would be great. I did the prototype p-t-p because of my complete inability to design circuit boards.
I have design for PCBs, but there my project stops. I go for BOZ to finish first my DCB1 build ... If DIY want design i can provide, but i never tested design in real life ... PCBs should be OK ...
ImPASSe PreAmplifier PCB !
I still have some boards for the preamp and power supply. I think that I moved about 100 of them since SY wrote the article. I asked, and Ed Dell gave permission to enclose a copy of SY's article with the boards.
Would be happy to have the DIYAUDIO store take this over.
I emailed and was given a link to purchase an entire kit and the variations of it. Maybe they are really busy but willing to just one currently? I am an frightened because of the lack of a good, simple build guide, being my first real audio project and not having tools to verify how correct my work is and make proper adjustments. Looking at the description I could only guess that the part listed as "Impasse PCB with Depletion MOSFETs adjusted to 8mA" might be key and the kit listed with certain parts pre-installed might be enough.
Sy, the article you have up is good, and probably has all of the information needed but for me it is like reading something in a language I had a couple of semesters in 30 years ago. I sort of get it and could order a beer in that language but there is no real comprehension of the project.
That being said, based on my experience here I don't doubt that with the help of members of this board I could make some real progress on the Impasse.
I could swing the $105 for the basic kit, the Cinemag part I could obtain within a couple of weeks - found a source for a little less. Then the power supply... about a month before I have cash for that.
Of course if I quit reading this forum 8 hours a day I might be able to put that time towards generating more income.
Yesterday I ordered the F4 boards from the DIY Audio store for building two monoblocks, so prioritizing - or more likely hesitating on which to build first.
The word hesitating, I don't like it. It's something I fight constantly. If I get an honest opinion if this is something I can complete within a month with the help of a couple or more DIY Audio members and without buying additional tools (I have nothing to test audio, only a simple multimeter) - then I will destroy that hesitation, have a great preamp and if it doesn't violate copyright - some effort at a build guide from the perspective of a newbie.
I seem to be the oddball here because making the chassis is the part I actually look forward to. Other than heatsinks, I probably already have the materials and tools to do either the Impasse or the F4's in a combination of stainless, aluminum or oak.
I wouldn't build the ImPasse as a first project since it deals with high voltages. Take a look at the OPA1632 from Texas Instruments -- it can be used as a single to balanced driver for the F4.
I put a set of vias on the board so that you could add a "matching" resistor to get both halves to be of equal current. Pretty simple to do-- just use a 10k pot in parallel with Rset and adjust until the current is 8mA -- remove the potentiometer and le voila, you've gotthe value you need to put in parallel.
In this case it was 2.37k.
This one didn't use WIMA's -- wanted to try another manufacturer.
The problem with the OPA1632 is the the rail voltages are limited to +/-16V, but to fully drive the F4 requires an input swing of +/-20V. I built an Impasse using Jackinnj's PCB and use it to drive an F4 (single-ended) from the output cathode follower. Unless you are using a pair of F4 channels in bridged mode, the Impasse balanced output is not necessary.I wouldn't build the ImPasse as a first project since it deals with high voltages. Take a look at the OPA1632 from Texas Instruments -- it can be used as a single to balanced driver for the F4.
Looking at the OPA1632 datasheet, it looks like a single-ended output swing of about +/-14V is the most you can expect when driven differentially. That would produce about 12.5 watts RMS output into an 8 ohm load. The max output is even lower when driven single-ended.
- ImPasse Preamplifier
