So going to finally put my dac together, looking at the regs.
Based on the datasheet, the lt3042 has a ground pad under the chip.
Ian's board has little holes and a pad to match.
Were you guys able to solder the chip pad to the board pad?
I don't have a hot air gun at home, so wondering if anyone was able to do it with an iron?
Any hints here would be appreciated.
Randy
Randy
Hi Randytsuch
I did a couple of them. I could not imagine doing it with an iron.
The LT3042 was my incentive to finally buy a hot air station. Picked one at Amazon. About $60 CAD. Best buy investment in DIY hobby. They work really well.
Second best investment was magnifying thingy with a light you wear on your head. I use this for everything now.
The LT3042 went on with no issue but use very little solder paste.
Hi Randytsuch
Thanks, that's what I suspected.
I've used a head band type magnifier for years now, I can't work without it.
Randy
I've been needing to post an update on my Ian GB setups.
First, I don't have any exotic clocks yet, so am still using either Crystek CCHD-957 or NDK SDA... both have some good points, I'm using the NDKs more often than the Crysteks.
I had posted how I'd been modifying the IVStd I/V stage filtering along with adding a Rasmussen-type pre-I/V filter, based on my personal preferences. My latest setup uses 1500pF SMD PPS film caps in the I/V stage feedback filter (stock is 270pF) and a 1uF/2R Rasmussen filter built into the DAC board connector. I've been going back and forth between LKS, Sparkos, and Burson discrete opamps. They all seem to be working a bit better with less high-frequency noise getting into them and the gap between them is closing. I'm currently using the latest Burson and think I might like them a bit better than the Sparkos and definitely better than the LKS to my ears.
Greg in Mississippi
Hi Greg
Did you add the 12nF coupling cap between the two stages?
Chan
@bigpandahk,
I'm not sure what 12nF caps you mean. I see the optional 3.8n caps to ground before the summing stages, but I don't see the 12nF caps. What am I missing?
In any case I am using the IVStd balanced output into a balanced amplifier, so I am not even installing an opamp into the U3 position.
Sorry!
Greg in Mississippi
P.S. I think @Markw4 tried caps in that position and they may have been 12nF. BUT he had oscillation there. I don't know if that wouldn't have happened if he used the specified value (I know he didn't use that, but don't remember for sure what he used... sorry, no time to search tonight). BUT as I say above, I don't even use that stage in my current implementation.
Sorry!
Greg in Mississippi
@Greg
Thanks for your reply.
Ian attached a pdf file in post #548 and there are 4 nos. 12nF Cap with a "?".
@bigpandah,
Thanks. I had forgotten that Ian had posted the IVStd schematic with the Rasmussen Filtering changes.
I'm attaching the schematic Joe Rasmussen had originally posted as the 3rd picture in the first post of this thread:
Practical Implementations of Alternative Post-DAC Filtering
Joe's comment about the 12nF caps:
"The 2 x 12nF caps can be finely tweaked to restore response to 'flatness' "
BTW, note the added .33F/5V supercaps, a technique adopted by Allo. Kewl that Ian provided positions for our DIY experiments along those lines!
Actually I have only used the pre-IV R-C filtering and not the 'equalization' caps. So no, I did not. At the tender young age of 63, I know I do not hear a db or so frequency droop at 20k.
Greg in Mississippi
P.S. IF one wants to argue the merits for or against the Joe Rasmussen pre-IV filtering regime, please refrain from posting here and feel free to start a new thread so it can devolve into name-calling and get closed as all of the other ones did. I WILL NOT ENGAGE in such discussion here. What I have said, that I'm really enjoying my Ian GB setup with a lower IVStd IV stage filter cutoff, using the Rasmussen pre-IV filtering, sporting NDK SDA clocks, and powered by Ian's LiFePO4 supply, is as far as I'll go.
Greg in Mississippi
There is something I don’t understand.
Why would supercapacitors be better than a good quality capacitor like the Silmic, black gate or Oscon (my favourite for digital).
I have been trying Maxwell supercapacitors 1,5f/5v on the rpi input and fifopi (on input and on the designated positions on the board) I did not find them to be better than a standard cap value.
The big capacitance has some disadvantages, it takes a while to charge (with high current), big capacitors have higher esr by design.
The supercapacitor will never be completely discharged while in operation. When using it on the input of the fifipi it takes like half a minute or longer to discharge after power down. So the most part of the capacitance will never be used.
The better choise will be to use a good quality cap with a standard value.
Does anybody have experience with Bursons v5i opamps on Ian's IV board? Would it be considered as upgrade from OPA1612? Massdrop is having a drop for them now.
Depends what someone would consider an upgrade. OPA1612 will produce the least distortion. Bursons will add a little perhaps euphonic distortion that some people like. Such distortion can be used to mask other distortion in the dac system that has not be otherwise corrected. On the other hand, if the dac has been cleaned up well by doing things such as adding Ian's shield board, and maybe the output stage filter mod, then maybe less remaining distortion to mask.
D
Deleted member 537459
I have burdon v6, but the trafo output is better, i don't if have distortion i listen and choice the better. I wait diy trafo. When i try them i write down my impression.
Ultra capacitor has the best low noise performance. As well, it also has super low internal resistance. So that it can deliver huge demand current in a very sort time to get best dynamic performance than any other power supplies. However the smaller ones have much higher ESR, so the performance will be very limited. Your feel is correct. (But still can provide some kind of compensations)
To make use of the advantages of the high current power ultra capacitor, it needs a special designed power supply. The scheme could be very complicated. I'm working on it but have no update so far.
Or, you can try LifePO4, it's not as difficult as ultra capacitor.
Ian
Couple more questions.
Anybody try an Allo Sparky SBC for this?
Wondering if it would be better for audio than a Pi. Seems closer to a pi2, no wifi.
Its just too bad shipping to US is so much, list price for card is low enough.
Anybody try the Allo Dietpi Web gui image?
DietPi - Allo.com Web GUI Image - DietPi / Fuzon
I need to setup my pi and found this today.
Anybody try an Allo Sparky SBC for this? .........snip............
'for this'...?... Ian's range of products is quite extensive...
Just finished an early prototype of custom wound high permeable cores output transformers for Ian's DAC. Currently only SE output is supported. Balanced output will be added in the future.
Bit thanks go to Ian for making such flexible and powerful sound platform!
View attachment 778204View attachment 778205
@xaled,
Looks very nice. Good PCB design. What are the I/V transformers?
Ian
@xaled,
Ian
Thanks! Board design was heavily inspired by your boards 😉
I/V transformers are custom made by my technical partner here in Germany. I will send you the board for evaluation once we finished the initial testing and are confident with the design.
Greetings,
Denis
This thread is mostly by users of his new ESS dual mono 9038 dac, but should have been clear.
Most use his fifo pi too.
The allo software only supports allo products, which makes sense.
I found a used sparky, so going to try it.
Let us know about your finding/tests as second-hand Sparky-ies may pop up more frequently due to the advent of RPi 4 and Allo's RPi CM-based DAC platform...
- PC Based
- IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
