Ian asynchronous I2S and S/PDIF FIFO KIT group buy
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
2 chansiukwing
3 lordvader 1*I2S FIFO KIT 1*Dual XO Clock board
4 karvid 1*I2S FIFO KIT 1*Dual XO Clock board
5 Blitz 1*I2S FIFO KIT 1*Dual XO Clock board S/PDIF Interface Board
6 daanve I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
7 Turbon I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
8 slartibartfasstI2S FIFO KIT -Dual XO Clock board
9 merlin2069er 1*I2S FIFO KIT 1*Dual XO Clock board
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board, confirmed right justified 16/24 support
11 andrea_mori 2 * I2S FIFO KIT - 1 * S/PDIF Interface Board-4 * 6" (need support left-justified format for SM5842)
12 ryanj 1*I2S FIFO KIT 1*Dual XO Clock board
13 Rupor54 I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
14 roenderI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
15 regalI2S FIFO KIT -Dual XO Clock board
16,17 PET-240I2S (FIFO KIT -Dual XO Clock board -S/PDIF Interface Board)*2
18 lwifI2S FIFO KIT -Dual XO Clock board
19 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
20 hochopeperI2S FIFO KIT -Dual XO Clock board
21 necplusultraI2S FIFO KIT -2* Dual XO Clock board
22 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 NicMacI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
24 SPWONG I2S FIFO KIT -Dual XO Clock board
25 MisterRogers I2S FIFO KIT -Dual XO Clock board, 3 x universal XO adapters, 2x BIII u.fl and clock adapters, 3*4" double-ended 50 ohm coaxial cable, 3*6" double-ended 50 ohm coaxial cable.
26 Atom6422 1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x 12” coaxial cable
27 hirez69 1*I2S FIFO KIT, 1*DUAL XO CLOCK BOARD, 1*S/PDIF Board, 3*BIII Adapter PCB INPUT (fully assembled), 3*BIII Clock Adapter (fully assembled), 15*XO Universal PCB Adapter, 8*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable, 4*12" double-ended 50 ohm coaxial cable
28,29 elecon FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
30 Rosendorfer I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
31 zinsula S/PDIF Interface Board
32 analog_sa1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x universal XO adapters, 1x BIII u.fl and clock adapters 7 x 4” coaxial cable
33 tjencks 1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4”
34 mravinsky 1 x I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
35 neb001 1x I2S FIFO KIT - Dual XO Clock board kit, 6 x universal XO adapters, 3x BIII u.fl and clock adapters
36 ccliu I2S FIFO KIT x1 Dual XO Clock board x1 S/PDIF Interface Board x1
37 florianderton I2S FIFO KIT, Dual XO Clock board, S/PDIF Interface Board
38 ENSen 1 x I2S FIFO KIT, 1 x Dual XO board, 5 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
39 CeeVee 1 x I2S FIFO KIT, 1 x Dual XO board, 6 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
Since we're getting down to the wire - added some hookup cables to my order.
Hi Ian,
I am trying to figure out what I need between different interface sources with my DAC that I will be building very soon.
I have both S/PDIF (CD transport), USB (PC) and I2S (some planed media streamer) as input sources, if I need to be able switch between those 2/3 sources, I will need the following:
1. WaveIO from Lucien for USB to I2S
2. S/PDIF Interface Board
3. Dual XO Clock Board
4. I2S FIFO Board
Then I can take the I2S from I2S FIFO Board and feed to my DAC ? Does it sound correct? Will the I2S FIFO Board able to take a incoming I2S input and output as I2S FIFO buffered ?
Yes, if you want to switch between s/pdif sources and I2S source, you have to use the s/pdif interface board together with the new updated V3.80 FIFO board. FIFO inputs I2S signal and outputs async I2S signal generated by new clock.
Ian
Hi Ian,
I know you said that until you have the GBII ready we should not sign up for this...but, in any case, I would like to order the following items:
.) 6 x universal XO adapters
.) 3x BIII u.fl and clock adapters
.) 6*4" double-ended 50 ohm coaxial cable
.) 6*6" double-ended 50 ohm coaxial cable
Let us wait for the pricing. I already have at home 1 FIFO and 1 dual XCO ...
Thank you,
Pepe
Hi lindamar,
Thank you for you order.
I ordered 50 FIFO KIT for GB II, so it still open 🙂. Could you please update the list by yourself, just in case I forget something. I'll list the GBII details this weekend together with the order form to fill in.
Have a good night
Ian
2 chansiukwing
18 lwifI2S FIFO KIT -Dual XO Clock board - S/PDIF Interface Board
I added the S/PDIF board as I am interested in the I2S backdoor (thanks for the very good guide).
Hi Ian
Just question... maybe it is not only me in that situation so I fought about asking...
I'm going in few days from now for my summer vacation, and not sure about Internet access down there ...
Any info regarding when You will be ready for payments and shipping...
Not that I'm in a hurry..... take Your time ..😎
Just would not like to miss the thing ...
Rosendorfer
Hi Ian
Rosendorfer
Hi Rosendorfer,
Everything will be ready by next week. I'll post the GBII details on this weekend. So, you can make the payment next week. But don't worry about the time. Enjoy you vacation is the first priority. I'll reserve the KIT for all the GBII registered members. I have enough to supply this time.
Regards,
Ian
2 chansiukwing
40 kvl 1x I2S FIFO KIT ,1x Dual XO Clock board,1x S/PDIF Interface Board, 3x universal XO adapters, 2x BIII u.fl and clock adapters, 6x 4" double-ended 50 ohm coaxial cable, 2x 6" double-ended 50 ohm coaxial cable.
2 chansiukwing
23 NicMac I2S FIFO KIT - Dual XO Clock board - 2*S/PDIF Interface Board - 6*Universal XO adapters, 2*BIII u.fl and clock adapters - 4*4" double-ended 50 ohm coaxial cable - 4*6" double-ended 50 ohm coaxial cable
Ian asynchronous I2S and S/PDIF FIFO KIT group buy second run (GB II)
Description
First of all, I’d like to express my thanks to all of the GB I user for your bravely taking the challenge to experience the new concept of digital audio. Your success built the foundation of this group buy II.
I promised opening GB II three months ago and it seems now it’s the time to run.
Again, here is the R&D thread which you could find all the details.
http://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter.html
But for many of us, thread is too long to follow up, so alternatively you can download the user’s guidance and other technical documents I attached below as a kind of sum up.
I’m trying to keep all the pricing as same as GB I, but the including items may have a bit change.
I’ll not supply the rubber rings this time because I still couldn’t find those with the suitable size.
Another thing is the 3.9% Paypel fee was too much for me. I’m afraid I have to ask you kindly sharing half of the Paypel fee with me which would be 1.95% of the total payment.
In additional to a Universal XO adapter KIT, a BIII adapters PCB will also be included in the FIFO KIT for free. And at same time, both of them will also be listed separately just in case someone needs more.
All of the Digikey part numbers of the accessories were given in the corresponding technical documents. You can buy them from Digikey directly.
Lists and prices
1. I2S FIFO KIT $149- USD/ea
Including:
- A finished and tested I2S FIFO Board with firmware V3.80 upgraded
- Two 8" single-ended PH 2.0mm 7-pin I2S cables
- One 2" double-ended PH 2.0 mm 7-pin I2S bridge cable
- One 6" double-ended U.FL cable for MCLK
- One 2" 10-pin FPC/FFC cable
- An 11.2896 MHz oscillator installed for function verification
- An universal SMT XO adapter KIT for free
- A BIII adapters PCB (input adapter and sync/async clock adapter) for free
- A jumper KIT for free
2. Dual XO Clock board $59- USD/ea
Including:
- An assembled and tested Dual XO Clock Board (double-sided SMT mounting)
- One 6” double-ended U.FL coaxial cable
- One 2” 10-pin FPC/FFC cable
- 22.5792 MHz and 24.5760 MHz oscillators for function verification
3.S/PDIF Interface Board $89- USD/ea
Including:
- An assembled and tested S/PDIF Interface Board
- Two 5” double-ended PH 2.0mm 7-pin I2S cables
- One 6” double-ended U.FL coaxial cable for MCLK output
- One 2” 10-pin FPC/FFC cable to interface with the I2S FIFO Board
- Two BNC to RCA adapters
4. U.FL coaxial cable connection accessories​
SMT U.FL socket $1 USD/ea
4” double-ended 50 ohm coaxial cable $2 USD/ea
6” double-ended 50 ohm coaxial cable $3 USD/ea
12” double-ended 50 ohm coaxial cable $4 USD/ea​
5. I2S backdoor KIT for S/PDIF board $3.99 USD/ea
Including:
- A 4 pin PH2.0mm SMT male connector
- A 4 pin PH2.0mm connector house
- Four 8” single-ended cables with PH2.0mm terminal (same or different color)
- A small piece of high temperature SMT tape
6. Package of Universal SMT XO Adapters lot of 5 $9.99 USD/ea
Including:
- Five Universal SMT XO Adapter PCBs (linked together with V-cut)
- Twenty pin terminals
- Ten 100n 0603 SMT MMLC for the optional decoupling capacitors
- Five 1u 0805 SMT MMLC for the optional decoupling capacitors
7. Additional BIII adapters PCB $3.99 USD/ea
Including:
- A input U.FL adapter PCB
- A SYNC/ASYNC clock adapter PCB
8. SMT connector package for BIII adapters $3.99 USD/ea
Including:
- A 20 pin 2.54mm SMT female connector header
- A 3 pin 2.54mm right angled pin connector
Please find the file name of attatched pictures for the meanings.
Terms and conditions
- All PCBs are factory assembled by Pb free SMT machines
- Loop tested and bit perfect confirmed
- Technical support by email or via DiyAudio thread
- Repairing for free within 1 year from purchase, buyers pay any possible shipping and parts
- I provide firmware upgrading service for free within 1 year from purchase, buyers pay any possible shipping
- No return for DIY KIT
Selection guide
1.If you just stick with one Fs I2S source and do not change it often, for example, 44.1 KHz I2S from a CD player, then the I2S FIFO KIT is working for you without any problem. You don’t need other two boards. With both 256*Fs and 512*Fs default MCLK frequency available,FIFO FW V3.80 provides more options for this selection. One XO frequency can run two Fs, and one Fs can use two XO frequencies.
2.If you Fs will change often or album by album, for example, I2S from a USB, then you will need the Dual XO Clock Board working together with the FIFO.
3.If you need including the S/PDIF input and output functions or you want to setup a S/PDIF FIFO, or you need switching input between S/PDIF sources and optional I2S source, then the S/PDIF Interface Board would be your choice.
4.With the FIFO FW V3.80 and the I2S backdoor KIT, you can include an additional I2S input source from the S/PDIF Interface Board.
Delivery and shipping
Delivery via Canada Post regular air mail without a tracking number. Will be in a 20x12x6.5cm box, around 0.5Kg
For 1 to 8 items, the shipping will be
Within Canada $8- USD
To USA $11- USD
For rest of international area $21- USD
I never have problem with Canada Post regular air mail so far. But please let me know if you really need a tracking number, I’ll quote for you from the post office. It may double the shipping to the international area.
How to buy
1.First, please register here in this thread by updating the waiting list (down if you already registered, but please confirm).
2.Then, to keep your privacy, please download the empty GBII order form (GB2OrderformEmpty.zip, excel format, pdf format just for reference) at bottom of this post, full in all the necessary information in blue section by excel, rename the file name staring by your order number on the waiting list and following by your Diyaudio ID(for example 23_iancanada.xls), send the finished excel order form file back to my email box: iancanada.mail@gmail.com
Following information are required in the order form:
- Your diyAudio ID
- Your PayPal account (usually an email address)
- Your email (if it is possible, use the same email as Paypal)
- Items and quantity you want to buy
- Shipping address (if it is possible, use the same as Paypal)
Please double check and make sure the shipping address is correct and with a postcode, otherwise it may result in losing of the parcel.
3. Once the items are ready for delivery, you will receive a conformed invoice based on your order from my email box with my PayPal account.
4. Making payment. PayPal only
5. KIT will be shipped within 7 days after getting the payment.
6. Confirm with me after you get the KIT.
I ordered 50 KITs for GB II, so it seems I have enought to supply this time. So now, the GB II is still open. New registers are welcome.
I’m very pleased having opportunity again sharing the KIT of this project with you. Just hope you enjoy!
Ian
  • DualXOGBII.zip
    DualXOGBII.zip
  • I2SFIFOKITGBII.zip
    I2SFIFOKITGBII.zip
  • SPDIFinterfaceBoardGBII.zip
  • Adapters.zip
    Adapters.zip
  • GB2OrderformEmpty.zip
Additional pictures of FIFO GB II
I run out all the 10 attachments of the above GBII details post. So, I have to post the rest 3 pictures here,
They are:
U.FL socket
Connector package of BIII adapters
Backdoor KIT of S/PDIF Board
Ian
Here we go:
2 chansiukwing
41 lindamar 2 x Universal SMT XO Adapters set , 3 x Additional BIII adapters PCB , 3 x SMT connector package for BIII adapters , 6 x 6*4" double-ended 50 ohm coaxial cable , 6 x 6" double-ended 50 ohm coaxial cable
@Ian : Shall I consider your standard shipping rate to a EU country ? (I am only buying accessories -no boards- that fit within a regular envelope)
best regards
Pepe
Here we go:
2 chansiukwing
42 bigpandahk 10 x SMT U.FL socket, 2 x I2S backdoor KIT for S/PDIF board, 2 x Package of Universal SMT XO Adapters KIT lot of 5, 4 x Additional BIII adapters PCB , 4 x SMT connector package for BIII adapters, (I've returned the FIFO to you for FW upgrade)
best regards
Chan
2 chansiukwing
43 cracra 1 * I2S FIFO KIT , 1 * Dual XO Clock board ,1 * S/PDIF Interface Board, 4 * 4" double ended 50 Ohms cable, 4 * 6" double ended 50 Ohms cable, 6x universal SMT XO adapters, 3x BIII u.fl and clock adapters, 3 *SMT connector package for BIII adapters, 3 *Additional BIII adapters PCB, 2 * I2S backdoor KIT for S/PDIF
best regards,
Camille
Here we go:
2 chansiukwing
30 Rosendorfer : 1x I2S FIFO KIT - 1x Dual XO Clock board - 1x S/PDIF Interface Board - 1x I2S Backdoor - 1x BuffIII adapter - 3x u.Fl 4"" - 3x u.Fl 6'' - 3x u.FL SMD socket.
Best Regards
Rosendorfer
haha this thing is huge!!
misterogers, I think we got our answer, probably we should still talk about possible PSU related GB, but theres no chance of beating Ian's bulk pricing when hes getting this many sockets
Great project!
2 chansiukwing
44 Eternalightwith - 1 * I2S FIFO KIT ; 1 * Dual XO Clock board ; 1 * S/PDIF Interface Board, 1 ; I2S backdoor KIT for S/PDIF
45 ruupie - 1 * I2S FIFO KIT ; 1 * Dual XO Clock board ; 1 * S/PDIF Interface Board, 1 ; I2S backdoor KIT for S/PDIF
Great! just in time! 😉
2 chansiukwing
