Ian asynchronous I2S and S/PDIF FIFO KIT group buy
It will be, just that the FIFO uses i2s in its buffer function for wants of better wording, I could well be wrong, qusp has one so will prob correct if so, Ian's SPDIF board is a receiver to i2s into FIFO to dac in i2s.
That's how my heads follows it. Not completely withit. Have son teething, those who have done nod, those who haven't, wonder "so?"
So I believe you output from the FIFO in i2s and ian had done the homework and hardwork to supply a correctly timed and structured data stream to the dac in i2s format.
Lots of hardwork. Don't envy the man!
Snaps for Ian!
Hey zibra,
Allgood. The iphone is not the best for this, I am pretty sure that the FIFO buffer uses I2S as its medium, so if you use the WaveIO from Lucien you could use the I2S from there into the FIFO, from the FIFO to the DAC of choice. Ian will need to clarify regarding which DAC you use and its format and whether he supports it, Im pretty sure he does though.
By using the Wave you can test between the SPDIF out from luciens board through Ians SPDIF board and the I2s direct to the FIFO, whichever is easiest to use and sounds best.
That better, can see why you were a touch confused earlier, part of parenting I think is english becomes your second language and tired drivel seems to replace it!
Hi guys
Im waiting for XMOS based converter from Lorien and have few questions regarding FIFO device.
1. Would it be still improvement to add FIFo to chain together with XMOS converter or converter should make its job alone with great results?
2. I use Spencer DAC now with I2S connection but I have plans for AD1865 DAC with SPDiF outputs only and receiver would be WM8804. Spencer uses CS8416 receiver. I assume in such case its better to use Ian SPDiF device for both DACs. Do I loose a lot in SPDiF connection vs I2S or its not that obvious when digital section is well implemented?
3. Is it worth buying dual XO board? What are benefits? Anyone tested?
I still search best solution from PC sound so if anyone tested mentioned above I would appreciate it🙂
1,FIFO is kind of async jitter eliminating solution. It optimized for clock, both logical and electronical. XMOS is also an async PC based solution if I'm not wrong. So, if XMOS comes with good enough low jitter clock better than what FIFO clock board could provide, then you don't need a FIFO.
2.However if you want to include I2S souce from a DIT such as CS8416 at same time, FIFO will work for you.
3. Dual XO Board provides frequency management for FIFO. With it, FIFO can switch between different Fs automatically. Otherwise, it will fix at certain Fs.
Ian
1 JamesHill 1*I2S FIFO KIT 1*Dual XO Clock board 1*S/PDIF Interface Board
2 chansiukwing
3 lordvader 1*I2S FIFO KIT 1*Dual XO Clock board
4 karvid 1*I2S FIFO KIT 1*Dual XO Clock board
5 Blitz 1*I2S FIFO KIT 1*Dual XO Clock board S/PDIF Interface Board
6 daanve I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
7 Turbon I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
8 slartibartfasstI2S FIFO KIT -Dual XO Clock board
9 merlin2069er 1*I2S FIFO KIT 1*Dual XO Clock board
10 roger57 1*I2S FIFO KIT 1*Dual XO Clock board, confirmed right justified 16/24 support
11 andrea_mori 2 * I2S FIFO KIT - 1 * S/PDIF Interface Board-4 * 6" (need support left-justified format for SM5842)
12 ryanj 1*I2S FIFO KIT 1*Dual XO Clock board
13 Rupor54 I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
14 roenderI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
15 regalI2S FIFO KIT -Dual XO Clock board
16,17 PET-240I2S (FIFO KIT -Dual XO Clock board -S/PDIF Interface Board)*2
18 lwifI2S FIFO KIT -Dual XO Clock board
19 vd-twoI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
20 hochopeperI2S FIFO KIT -Dual XO Clock board
21 necplusultraI2S FIFO KIT -2* Dual XO Clock board
22 lllI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
23 NicMacI2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
24 SPWONG I2S FIFO KIT -Dual XO Clock board
25 MisterRogers I2S FIFO KIT -Dual XO Clock board
26 Atom6422 1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x 12” coaxial cable
27 hirez69 FIFO KIT, Dual XO Clock board, S/PDIF Interface Board,6 X SMT U.FL 4 X 6” and 2 X 4” double-ended U.FL cables (and 14 XO adapter PCBs)
28,29 elecon FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
30 Rosendorfer I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
31 zinsula S/PDIF Interface Board
32 analog_sa1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4” coaxial cable
33 tjencks 1 x I2S FIFO KIT 1 x Dual XO Clock board 3 x 4”
34 mravinsky 1 x I2S FIFO KIT -Dual XO Clock board -S/PDIF Interface Board
35 neb001neb00135 neb0011x I2S FIFO KIT - Dual XO Clock board kit
36 ccliu I2S FIFO KIT x1 Dual XO Clock board x1 S/PDIF Interface Board x1
37 florianderton I2S FIFO KIT, Dual XO Clock board, S/PDIF Interface Board
Please let me know for any question.
Ian
38 ENSen 1 x I2S FIFO KIT, 1 x Dual XO board, 3 x universal XO adapters, 3x BIII u.fl adapters (if possible)
2 chansiukwing
27 hirez69 1*I2S FIFO KIT, 1*DUAL XO CLOCK BOARD, 1*S/PDIF Board, 3*BIII Adapter PCB INPUT (fully assembled), 3*BIII Clock Adapter (fully assembled), 15*XO Universal PCB Adapter, 8*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable, 4*12" double-ended 50 ohm coaxial cable
Thanks Ian
hirez69
2 chansiukwing
38 ENSen 1 x I2S FIFO KIT, 1 x Dual XO board, 5 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
Ian, I don't know the availability of coax cables and BIII adapters so please regard this as a wishlist from me.
2 chansiukwing
39 CeeVee 1 x I2S FIFO KIT, 1 x Dual XO board, 6 x universal XO adapters, 3x BIII u.fl and clock adapters, 6*4" double-ended 50 ohm coaxial cable, 6*6" double-ended 50 ohm coaxial cable.
2 chansiukwing
32 analog_sa1 x I2S FIFO KIT 1 x Dual XO Clock board 2 x universal XO adapters, 1x BIII u.fl and clock adapters 7 x 4” coaxial cable
2 chansiukwing
35 neb001 1x I2S FIFO KIT - Dual XO Clock board kit, 6 x universal XO adapters, 3x BIII u.fl and clock adapters
Hi there,
Great work going on here !
I would like to be in on the next group buy for Dual XO board, universal XO adapters, BIII u.fl and clock adapters and 6*4" double-ended 50 ohm coaxial cable. Is there a price list and when will deliveries start?
Ian
Hi Ian,
I am trying to figure out what I need between different interface sources with my DAC that I will be building very soon.
I have both S/PDIF (CD transport), USB (PC) and I2S (some planed media streamer) as input sources, if I need to be able switch between those 2/3 sources, I will need the following:
1. WaveIO from Lucien for USB to I2S
2. S/PDIF Interface Board
3. Dual XO Clock Board
4. I2S FIFO Board
Then I can take the I2S from I2S FIFO Board and feed to my DAC ? Does it sound correct? Will the I2S FIFO Board able to take a incoming I2S input and output as I2S FIFO buffered ?
Hi there,
that would be on the first page of this very thread …
when they are ready =)
Thanks guys, almost done. It seems I can finish everything and get them posted this weekend.
I'll make one set adapters for free per KIT. But I'll also list them in case you want more.
Regard,
Ian
Hi Ian,
I know you said that until you have the GBII ready we should not sign up for this...but, in any case, I would like to order the following items:
.) 6 x universal XO adapters
.) 3x BIII u.fl and clock adapters
.) 6*4" double-ended 50 ohm coaxial cable
.) 6*6" double-ended 50 ohm coaxial cable
Let us wait for the pricing. I already have at home 1 FIFO and 1 dual XCO ...
Thank you,
Pepe
