HDMIpi transmitter will be $35-
HDMIpi receiver will be $25-
Please put your name in a list if you are interested in, I'll get back to you after I'm back from vacation.
Ian
FifoPiTransmitter by Ian
FifoPiReceiver by Ian
Ian
anyone in Australia who would want to help out with soldering the CCH957 XO and the capacitors, please PM me.
Thanks!
Thanks!
Hi Ian,
Would you provide HDMI wiring diagram?
I'll when I come back. It's the most standard configuration, It works with all the DACs that I've tested.
Regards,
Ian
HDMIpi List:
1. JoeyDD: transmitter x2, receiver x2
2. JimS: Transmitter x1, receiver X1
3. Big Bird: transmitter 1x
@ian
I received my universal SMT XO Adapters KIT today but the package only contains one type of capacitors. I thought there would be two types of capacitors? Maybe someone can tell me the capacitance and size of the capacitors that are normally contained in the package?
With regards, Big Bird
4. myint67 receiver 1HDMIpi List:
HDMIpi List:
5. linh0983 transmitter 1x
HDMIpi List:
6. lindamar: transmitter x2, receiver x2
HDMIpi List:
7. Lucser: transmitter x1
Hi Ian,
Is it possible to have I2S HDMI transport multi-channels for McFIFO ?
(3 channels for me)
nounouchet
(3 channels for me)
nounouchet
CCHD957 adapter kit
After assembling the CCHD957 pcb I checked the resistance between pin 2 (gnd) & 4 (vcc) and it showed a short (0Ω), so I went back and reflowed (no joy), then started removing caps until no short, but it was around 130K. Does this seem about right?
HDMIpi List:
8. flyboi : transmitter x1, receiver x2
Hi to all
Yesterday I mounted all the boards the I recveived (FifoPi + dual ES9038 DAC + ESS Controller + Standard I/V)
I have 2 different problems:
1) If i mount the ESS controller on the Non isolated GPIO of the FifoPi the controller doesn't work. At all. The LED of the controller remain completed turned off (during the startup of the raspi, on the led of controller i can see some little light (some point flash) but when the startup procedure is finished the LED becames black). Instead if I mount the controller directly on the DAC (on top of the FifoPi) the controller seems to work; The light is on on the led and also if I stream music the controller show the right information on the audio stream. COULD BE A PROBLEM ON THE FIFOPI ? ANY SUGGESTIONS ?
2) From the I/V Board I'm not able to ear anything. Also in the case that the streamer seems to work properly, the ESS Contraller (mounted on the DAC directly) show the audio stream info, all the led on fifopi and DAC became green during the streaming, from the I/V Board doesnt exit enithing. ANY SUGGESTION ?
I'm using Raspberri Pi 3 with DietPi with MPD client and also Jriver Istalled
I'm using a PC power supply (waiting the LifePO4) to prower the FifoPI with 5V and 3.3 V , To power the DAC with 3.3V and to power the I/V board with +12V 0 -12V
HDMIpi List:
9. mksung: transmitter x2
HDMIpi List:
10. pierantonio: transmitter x1, receiver x1
Looking good but no music
I’ve assembled LifePo4+RPi+FifoPi+ES9038Q2M+ESS Controller +Standard I/V and installed Volumio on the Pi. All looks to be ok, except there’s NO music when I play a track. ESS controller displays appropriate signal etc, just no sound from my hifi. Any thoughts to help a noob. Some pics attached.
Is the volume loud enough?
- Group Buys
- Ian asynchronous I2S and S/PDIF FIFO KIT group buy
