I got my new lamp. It is for commercial projection use. people use it to replace the
CCMCornell said:
ywh,
Do you still have access to the first light set in the thread with the 6500k color temp? Are there any options for USA voltage?
no,I give up 6500k color temp now, every one choose 9000k if he seen two light at the same time.
get a ballast in usa,the voltage is OK.
Steamer said:
I checked back a couple of pages and you say the lighthouse is $25. Is that with the condensor and reflector? if not, how much for the full lighthouse setup with the condensor, reflector, and the FC2 connectors?
Steamer
yes! $25=condensor, reflector, and the connectors.
but i for forget FC2 is for 150w or 250w?
250w connectors are two single part. you need fit them on the lighthouse yourself.
Re: Looking for 200W UHP replacement lamp
Steamer said:
the FC2 connectors I would need are for the 250W.
Thanx
Steamer
OK! pay to 18
softikuss said:
I am looking for a 200W UHP replacement lamp if possible with the reflector for my Sony VPL-VW10 projector
Take a look how it looks like:
http://edad.pair.com/mabi/tmp/sony_lmp-p200_3.jpg
Inside the cave it looks like this
http://edad.pair.com/mabi/tmp/sony_lmp-p200.jpg
Can anyone help me or does anyone has already made
experiences with this type of projector / lamp ?
Thanks!
Hi! I sent e-mail to you.
RymGB said:
YWH,
Could you please post an email address I can contact you on (or PM it to me).
I’d like to contact you in regards to getting one of these 250W UHP lamps + ballast. Maybe also a light house.
Ray
yuweihua@tom.com.
ywh,
I have already written you that in an email but it seems to have not properly reached you. Is it possible to chat with you? I tried your ICQ number (from your profile) but I do not see your buddy online. Please let me know how I can reach you beside this public forum (i.e. email or chat) .
Thanks very much!
Re: Re: Looking for 200W UHP replacement lamp
ywh said:
Hi Yu
I have just tried several times to write to your email address but I always get a mailer daemon failure notice
Hi. This is the qmail-send program. I'm afraid I wasn't able to deliver your message to the following addresses. This is a permanent error; I've given up. Sorry it didn't work out.
<yuweihua@tom.com>:
Connected to 202.108.252.141 but sender was rejected.
Remote host said: 550 CoremailSys😀omain in Mail from user is illegal.
Sometimes I get other messages, your inbox is full etc. I have sent again my email as PM through this forum, please get back to me as soon as you can.
Thanks,
Markus
wow that was alot of reading,
ywh,
are these 250W 9000K UHP bulbs still available?
What are the exact specs on the bulbs, im trying to figure out
what kind of ballast will be needed in North America. What about the ignitor?
From what Ive read so far, to drive these bulb the ballast has to put out 250W, ~100V, ~2.45A??? Will 100V @ 3Amps work? Also what kind of ignition do the bulbs need?
Thanks for the help
yes, these 250W 9000K UHP bulbs are still available.
it is new production, i dont know how about in North America.
about 20000lm
250w/400w
Hello Yu,
hello 18W,
today I have got the lamp JYd200/Dc and I could successfully
fit the bulb into the case. It now looks exactly like the orignal
one.
The projector worked fine for the first 5 minutes, light output
was somewhat darker than with the original lamp. Light was steady for about 5 minutes.
The problem arose after 5 minutes of usage. the projector began to stink, and the light output suddently became less and less and
after anothe r30 sec there was almost no light output anymore!
I switched off the projector (Sony VPL-VW10) ad once and I will
test again tomorrow with the original lamp. The fressnell lens
looks still ok and I really hope the LCDs did not sustain any
damage.
****... I was hoping to have an alternative with your lamp.
Any ideas if there is another option, a lamp with less operation
temperature (but at least the same light output)?
Salut, Markus
Hi all, this is my first post. I bought myself a 3M 9550 OHP and a iyama 15" tft monitor not so long ago now. I've been over the moon with it and it still performs ok even though the little thick lens near the lamp has a crack in it (if anyone has a spare or knows where i can buy one new please let me know)...
I've just found an opertunity to buy these items second hand for only £37:
150W Metal Halide Lamp
Lamp Base
Ballast unit
Well my idea is to simply place this MH lamp in place of the existing halogen lamp (removing the halogens obviously). The lamps physically look very similar (single ended) and i hope it will take minimum modifications to use in the 9550 body.
Am i on the right track here? If it works should i strip out the 9550's electronics and fit the ballast etc inside the 9550's case?
Xy.
Kind of off topic
I was looking through ebay today and found a seller that sells the lamps/reflector for lcd projectors. Just the lamp no cage etc. Anyway the interesting thing is he says for instance 120 uhp projectors can use the 150 w UHP Bulbs and since they are being underpowered will last many more hrs . Sounds interesting and I am wondering about this but dont have the confidence yet to try it( I would just hget the 150w one from YWH By the way. Any thoughts???? Here is a Ebay link for a example 5842299522 PS NOTE IM not saying BUY THIS LAMP FROM THIS EBAY SELLER................IM just using it for information........ 😎
Infocus sp110 replacement bulb
Hi to All,
I have infocus SP-110 this projector using 220 watt (mercury) bulb not UHP but UHM. YWH and 18wheeler do you think the UHP are compatible with this projector bulb your selling? I was planning to buy from you the replacement bulb for this projector.
The projector came without the bulb so i cannot show you how its looks like.
Thanks in Advance,
Aaron
ywh said:
HI ! Steamer
lighthouse was on the way!
[Editted by Mod Squad]
Thanx YWH! I got it last week. I'm finally almost done with my yearlong project! (is that an oxymoron? -finally almost? Maybe I'm the moron)
YWH, Do you or 18Wheeler happen to know the specs of the condensor and reflector? I mean, what are their respective focal lengths?
Steamer
Got my new 120 watt UHP lamp from YWH,i have installed the lamp in a commercial projector with very good result.The reflector is very small,about 1 1/2 inch diameter but the lamp fit very well,i had to make a small 1 inch hole on the back of the projector to make it possible .
My projector is very small ,7 inches wide by 6 inches large, 2 inches high. OLYMPUS VP-1 ,1024 *768,1000 lumen with 2000/1
contrast ratio.I can't see the difference with the original lamp,the result is incredible.
Thanks to YWH and 18wheeler for their support.
Hi all!
That's my first post and I have a few question to YWH and 18wheeler. Recently I've bought an ASK IMPRESSION 960 projector. It is not a modern one, but got it rather cheap. It uses MH 575W GS dual ended bulb. Bulb has 750h lifetime and still has 300h left. After it burn out i wonder what would be better:
1. Modify projector to accept metalohalogen lamps (eg.250W HQI lamp approx 23000lumen 8.000h life time) Would the picture in this case become too dim?
2. Find a cheap 575W bulb - i found one at you store around 40bucks. But - I live in Poland. Would it be a possibility to sent this item to Poland? Do i have to acquire paypal account or maybe any other methods are to make a transaction?(These Bulbs in my country are for approx 180bucks)
Last question is - when my lamp reach end of its life - 750h - should I uncoditionally remove it or can I use it longer? In other words - will it explode and damage my projector or slowly fades to black??
Thanks in advance for replying
