I got my new lamp. It is for commercial projection use. people use it to replace the
HELP !
I´m checking this thread frequently.
I have a E-ballast 200W with input-voltage of 365V-380V for DC burners.
how can I run this in Germany with 230V?
I plan to buy also a UHP from YWH.
@YWH do you have 250W AC-burner? if yes I would need the specs please.
thanks
speed.cat
my ballast has a PFC converter and should work from 110-240V, so it´s ok.
my lamp is DC200W.
what is the advantage or disadvantage of DC lamps?
what is the advantage or disadvantage of AC lamps?
@ YWH:You have probably the experience?
here´s a pic from my lamp
what does all this wire do???
I know, that AC lamps do not have the wire.
please help
speed.cat
YWH
I read almost every post, And I'm am now almost certain I can use my IceCap e-ballast. The problem is, it says the output is 250W 120V. Is that too much?
Can someone please help me out? I like the color temp and life. But if it is less life with a 250W ballast, maybe I want a 150W ballast? Then again, maybe I don't want to spend that much to replace my current setup of the IceCap 250W, with an HQI TS 5500K 2000H double-ended bulb that I can get for a little over 40$ US from a UK lighting company.
Steamer
hi speed.cat!
I have 200W DC lamps
do you sure you need DC lamps? a few projector need DC lamps,
hi Steamer!
i can not sure that your e-ballast is nice for my UHP lamp.you can try it.
my lamp is 7500k-9300k.9300k is news.
i have HQI too , 9000K, 6000H double-ended bulb, 40$ US too.
hi 18wheeler! once again.
