I got my new lamp. It is for commercial projection use. people use it to replace the
Hello yuw, problom with my 270w bsm-dc burner
Hello yuw,
I have received my 270w bsm-dc burner and cannot get it to start. I have tried plugging it into both my SharpVision XV-Z10000U and my XV-Z12000U projector nether will light the lamp.
To further test my projector I have installed a old lamp and it starts no problem.
If you can tell my how many DC volts are to be used with the burner, possibility I can test the burner with an external DC power source.
WDC
Ps do you test the burners before shipping them?
Hi crazifunguy !
I have no time this week, please wait.
Hi rockrider81 !
are they 150W P-VIP and 180W UHP ?
you need 150w BSM-AC and 200w-AC, price is $80 each.
Hi Kevbabe !
is you bulb UMRD250NE ? you need 250w BSV-DC, $40 each.
Hi WDC !
all of burner had been tested before it out factory, the wire had been burned.
some ballast of SHP are low volts start , can not start in 110v .
the operating VOLTS is 75v, start volts is 15 kv
you can send bulb back to me
SANYO PLC9000EA 400watt UHE lamp ?
Hi YWH
Can you do a replacement for a SANYO PLC9000EA 400watt UHE
(Metal Halide) lamp ?
OEM Part = 610-290-7698 / LMP15
