hello ywh, i bought a used mitsubishi lvp x100e i think it takes a 280w bulb with consumption of 330w dont know what that means, id like to know 2 things
1 can you or anyone recommend a way to test this ballast out of the projector? im thinking of salvaging the lens and ballast since i cant get it working
2 do you have this bulb and how much $$$ would it be to texas
thanks alot for your help
Hi tommygaus !
you need 200w BSM-DC, price is $80, shipping is $5. fee of paypal is $4
Hi thedarlington!
My 280w UMPRD can do it , price is $90, shipping is $5. fee of paypal is $4
about your ballast, can you found the optical coupler like this one, short it = power the ballast.
Hi thedarlington!
![光耦-EL815、、816、817、819.jpg](https://cn.made-in-china.com/image/2f0j01aMwEDbUBsfoYM/光耦-EL815、、816、817、819.jpg)
Hi YWH.
Just checking to see if you have rebuilt my lamp an shipped it yet. I paid thru paypal about two weeks ago.
Thanks,
FDC2007
Coltman1966@verizon.net
Thanks,
FDC2007
Just got lamp in mail
Hi Ywh!
Just got my lamp in the mail.
I was trying to reset the projector's lamp timer and can't figure out what I am doing wrong. The projector's lamp does not always want to come on and I think it may be because the timer still "thinks" the lamp needs changed. It won't reset for me.
Have you had any experience with that? It's a Sharp XR10X.
Thanks,
John
FDC2007
Hi Ywh!
Thanks,
John
FDC2007
Hi FDC2007 !
did you need this: http://www.ercservice.com/PDF/Lamp-Sharp-XR10-XR20.pdf
RE: Sharp Lamp reset
YWH,
Thanks for getting back with me. I tried that already and I can't get it to reset. Is there a specific sequence that the buttons need to be pushed? Anyone else have this problem?
Thanks,
John
FDC2007
Hi FDC2007 !
YWH,
Thanks,
John
FDC2007
Sharp XR10X
Thanks for the info. YWH that took care of it. Amazing how one thing out of order can throw everything off.
I am also having trouble with the lamp coming on periodically. I can hear it make a sound as if it wants to come on but does not always want to. I changed it to another bulb and it is doing the same thing.
Anyone have any ideas on that?
Thanks,
John
FDC2007
Thanks,
John
FDC2007
Try here: LumenArc - 150W AC Projector Lamp Bulb - Low Voltage Ignition
I've placed an order a 250W AC Burner. Hope it arrives quick fingers crossed. By the way, is it not possible to buy the cement the manfacturers use. What is that cement called?
Sorry, forgot to mention it's a 200W philips ballast.
Or is there no difference in the bulb?
The SP5000 lamps seems to die quite fast and easy...
Other question:
If I would use a 250W bulb:
Would it start?
Would it extend the lifetime?
Be better for heat?
Or destroy my 200W ballast?
Other question:
Would it start?
Be better for heat?
Lamp will not light Sharp XR10X
I have a Sharp XR10X that has to be reset about 4 times or so before the lamp will light. I reset the lamp timer and still the same problem.
Someone had also mentioned about a reset switch inside. I tried that as well and still the same problem.
When you try to turn the lamp on you can hear it make a faint sound like it is trying to light but the sound goes up and down like a low pitch whine or whistle.
Anyone have any dealings with such a problem or where I can go for an answer?
I have two different bulbs and bother react the same way so I don't think it is the bulb.
Thanks,
John
FDC2007
Thanks,
John
FDC2007
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
