i use transformer ouput: 220V.
so DC for HV ~295- 300 VDC.
you use 240 V??
I don't have a transformer yet. I can easily get one with 240V secondary. Can I have a 220V B+ with a 240V transformer?
yes, it is easy with trimmer one board No,shunt
thanks
Quanghao: Yesterday I ordered 1 pcb HQ-IV tube output from your store,but
does it come with the PSU board the No shunt pcb?
Or where do I get it?
Dear Quanghao,
I haven't heard from you since I have resent mu data to you by e-mail. Can you please update me? Thank you
Hi mvictor69!
I have prepared for your PCB.
I'll send it tomorrow, along with your following 2
hartbigsky
Ryssen
thanks
hartbigsky
Ryssen
thanks
ok, no problem, i sent you with pcb supply, and you payment me later.
thanks
Quanghao, there are jumpers on the PSU board at H1 and H2 that allow you to connect the filament ground to the HV ground (H1) or to HV +70V (H2.) I understand this is to keep the voltage differential between the tubes' heaters and cathodes within spec, but none of the pictures on this thread have shown people connecting them. You mentioned it in post #209.
Is it best to connect H2?
jonwhitear; . You mentioned it in post #209. Is it best to connect H2?[/QUOTE said:i see all the sample. please simple connect -F to GND HV!
thanks
can´t find upc1237 and LT1764 at mouser,di anyone else find them there?
You'll need to resort to eBay for the upc1237. The LT1764 is standard, so should be available through mouser etc.
http://au.element14.com/linear-technology/lt1764aet-pbf/ic-ldo-reg-3a-ln-to220-5/dp/1663484
Hi Quanghao,
i payed 70 USD for the boards at 31th of Mai with PayPal.
i send you a PM, but got it back, cause your account exceeds?
regards Frank Wilker
Hi Quanghao,
hi!
you can not payment it ??
thanks your advice
quanghao
Hi mvictor69!
I was sent tou agian PCB = 2 x PCB IV + 2 PCB No,shunt.
if this time you can not get them, i will not sent again.
thanks you very much.
And i was snet for:
hartbigsky: 1 x HQ IV
Ryssen : 1 X hq iv + 1 X no.shunt
thank all
quanghao
And i was snet for:
thank all
quanghao
Is it true that you lose about 140v in the HV regulator?
I got one trafo with 240v AC
and one with 260v AC
will either of them work?
I'm using a 240V taro, and seems to work fine for me. I haven't finished the I?V board yet, but I've hooked the filament and HV transformers up to the SPU board and both work OK, i.e. I've adjusted the filament supply to 12.6V, and the HV to 220V.
Hi mvictor69!
And i was snet for:
thank all
quanghao
Thank you. I hope it will arrive this time.
Victor
- Group Buys
- HQ-IV tube output balance DAC
