How to make a loudspeaker sandwich cone
Feedback on the use of a new type for glue for the thin foil from the goldsmith.
Easier work with methylcellulose - its the glue used for wallpapers.
It has less damping properties than the "Anlegemilch" usually used for thin foil metals but its easier to work with and tidier work is possible.
It has stiffening properties.
Here I tried it on piezo drivers. Will measure if there is a benefit using sandwich technology on piezo paper cones.
Reactions: L.rivera92172
made a series of measurements
Arta f response and waterfall
4 no name piezos and one
Monacor MPT-142
all have filter:
12 ohm in line 1uF in line, 91 ohm across plus and minus on the driver
no name piezos
1 driver original
2nd driver 1x alu foil
3rd driver 2x alu foil - sandwich
4th driver 2x alu foil + damped cavity with medical cotton
5th driver Monacor MPT142
2x foil plus damped cavity
especially on piezo cones the cone stiffening foil raises resonance frequency. Due to the lack of a real suspension.
The suspension was not covered with foil.
The quality piezo MPT142 shows better linearity.
Very effective is the damping of the cavity with medical cotton
now the drivers from post 3 came to use in the doors of a VW Touran car
Defect driver replaced
loudspeaker from post 150 got protection grill.
Will make a RCL filter for the +15db peak at 1.8khz.
Simulation shows for a test 15uF, 0.37mh and 10 to 20 ohms for taming that unpleasant peak
in a previous design I put the tweeter concentric in front of the driver. Always sounds good like this.
This time I put it above the fullrange driver.
Turning the box shows the highs sound better integrated with the tweeter at the side, so distance to the ear changes for better.
