Hornresp
Harry followed, but Disney did not like it!
Harry Potter Day at Disneyland
Hi Bill,
Thanks for the link - very interesting. I guess the Harry Potter fans were lucky to be allowed into Disneyland at all, given that Warner Bros. made the movies 🙂.
I must admit that I was quite surprised when I first learnt that TimeWarner had won the film rights. I had automatically assumed that it would be Disney - I am pretty sure it would have been, if Walt was still around.
Kind regards,
David
Things Quantum
Hi Bill,
Kind regards,
David
David,
Here is a far more interesting read:
Have We Been Interpreting Quantum Mechanics Wrong This Whole Time? | WIRED
Bill
As far as I understand, the universe is big.
Really big.
Then think bigger er.
Interesting article Bill.
Articles like these tend to make me wonder why so many ideas that are supposed to be decided scientifically analysed and weighed on their merits don't get the attention they deserve. What seems to be the case is that they the prevailing winds of thought are more ego driven than anything else.
One observation I had back in 1979.
The universe is 5 billion years old.
Now 36 years later it is 13 billion years old.
Talk about rapid aging!
Bangs, Big and Small
Really big.
It is at the dimensional extremes that everything behaves in a non-Newtonian manner; whether infinitely small or infinitely large. The universe may simply undergo transitions from one of these states to the other and we just get to measure the span of the current epoch only; so for us, it is just a "Big Bang" for now.
Bill
David I have been able to use some of the new features.
I like it!
I like it a lot!
Have a bit of a question in setting up a compound horn.
Bill Geiger has presented a interesting mass loaded tapped horn that I have been able to model correctly once.
Then my computer crashed and I have not been able to do it again.
Stupidity on my part.
The compound horn requires quite a large compression chamber to be modeled correctly.
Hi Mark,
I'll attach what I would consider a typical CH simulation. How did you get the tapped horn feature (front-to-back foldback) of whgeiger's design into a Hornresp compound horn?
P.S.: I added whgeiger's design pdf.
  • LAB15_CH.txt
    LAB15_CH.txt
  • AWC15.pdf
    AWC15.pdf
Hi Mark,
So, what is the question? 🙂.
Why do you call it a "mass loaded" tapped horn?
The simulation model developed by Oliver and linked in the post below is probably as close as you are going to get to Bill's design, using Hornresp.
http://www.diyaudio.com/forums/subw...binet-16-hz-organ-speaker-35.html#post4443937
Bill's suggested "reentrant" tapped horn design should not be modelled as a compound horn. A standard Bose Acoustic Wave Cannon type design on the other hand, should be.
Kind regards,
David
