Hiraga "Le Monstre"
Can you redesign the circuit to use the 2SK170BL grade? Would also be interested in the gerbers for the pcb if you can sort out the JFet problem.
By the way, I would not trust any devices from the company you mention in post #1998.
I already have GR grade jfets but want the 1,3 mA Y-grade one´s.
I have a BL grade(operate at 2.3mA.) and I changed the values of the resistors to stay as close as possible to the original operating points. I didn't find Y grade anywhere.
"Y" grade is not even mentioned in the Toshiba datasheet for the 2SK170 JFet.
Check the 1983 data book (it's been linked to round these parts multiple times already).
The Y's are unavailable, period.
You might mangle the 2SK170Y out of obsolete equipment, the 2SJ74Y are cast in the everlasting black hole. Another period.
Keep an eye on Yafuoku (and be prepared to pay through the nose 😉). But given the Y's are 1-3mA, finding ones at 1.3mA in particular may complicate the matters a wee bit. 😛
Alternatively, you could give 2SJ44K / 2SK163K a try - while their Yfs is ~1/3 lower, they are *much* easier to find (even in quantity for matching purposes), low noise, and - supposedly - truly complementary (which the Toshiba's aren't).
Thanks alot, I have sent some mail requests for 2SJ44K/2SK163K but most of them are not K-grade out there.
I bought some of the K grade NEC transistors from Wakamatsu in Japan a year or so ago, and they still have hundreds in stock. At that time, Tokyo Adcom also had plenty in stock, but Wakamatsu came out cheaper. (Not sure though if either of those companies can / will communicate in anything else but Japanese.)
J44 / K163 also pop up on Yafuoku every now and then - even matched pairs...
BTW, K163 was later replaced by K523 (identical specs) and K533 (lower IGSS, 100pA vs. 1nA, otherwise identical), which may simplify the search. No alternative for J44, as far as I know.
RE Utsource: I've seen their name mentioned in several threads about fake components here, so I personally would not trust them. On the other hand, most people don't even know a Y grade of J74 / K170 existed - the internets are full of counterfeit GR, BL & V parts, but I've never seen a single J74Y or K170Y listed on eBay and such. People don't know about them = no demand = no fakes. Hence, there might be a minuscule chance Utsource have the real deal... but I somehow doubt it.
...setup email alerts...
Man, I'm from the analog prehistory. I'm a analog dinosaur. My lair is stuck with clay tablets and papyrus rolls about electronic specifications, applications and service manuals. All chisseled with scratches and polluted with graffity. Have mercy!
BTW, where does the 1.3mA figure come from? (Post #1181, perhaps?)
Unless I'm mistaken (and I quite often am 😀), the 1.3mA is not the IDSS of the JFET itself, but rather the ID an average Y grade JFET (IDSS ~2mA) would pass when degenerated by 50R (1/2 of the 100R trimmer). Which would mean that a JFET from the very bottom of the GR grade range (IDSS ~2.6mA) should get you pretty close to the target.
A trusted seller of the Toshiba JFETs and a member of this board, alweit, used to be able to supply the lowest possible IDSS GR grade parts specifically for Le Monstre builds in the past - not sure if he still has some available, but there's no harm in asking...
