Hiraga "Le Monstre"
Hello Kenev,
If you want to just view the design in a gerber viewer, I suggest you install gerberlogix viewer.
If you want to import gerbers in a PCB design software, sprint layout imports the gerbers to appropriate layers and lets you modify the design as required.
regards
Prasi
Hello Prasi,
I tried to import the Gerber files in Sprint Layout, but I get the drill holes spread over a large area outside the board itself. See the attached image (here, I have imported just the bottom copper and drill data files).
Thank you,
Evangelos
Hello Prasi,
Thank you,
Evangelos
Hello Evangelos,
There are some settings with sprint layout while importing drill layer ... do explore those options, it solves the problem of inches and mm drill layer coordinates of gerbers in sprint layout. I have done this many times before, but now I no longer have sprint!...so i wont be of much help here...
regards
Prasi
Hello Evangelos,
regards
Prasi
Thanks, Prasi,
I played a lot with the parameters of drill data and, finally, I managed to sort this out. In particular, "Unit" has to be in mm and I had to try a bunch of combinations in "Numeric format" to get a proper board.
Anyway, thank you again.
Evangelos
Thanks,what is the transistors that you using and what is the bias current?
My PCB and transistors were an old kit from Jim’s Audio on eBay generously given to me by Fab (USSA5 designer), thanks Fab ! The kits didn’t have the output transistors so I ordered some from ON semiconductor.
My amp is not the typical 8W, I used higher rails (+/- 17Vdc) w bias (1A) to get about 15W / ch. I have attached the schematic, notice the big cap following the Cap-Mx.
Have fun
Eric
Reactions: rubah.ganteng
Have fun
Eric
Nicely done Eric, yes the huge cap after cap-mx should help a lot.
regards
Prasi
Have fun
Eric
Thanks Eric.
Nice done! I see a 200R resistor between the collectors of the drivers. Is it your mode?
I can't see this in the original schematic.
I have used, 2sk246,j103 for input, all other bc550, 560,TIP35,TIP36 as output.
2SK246,J103,2SC1845,A992,MJL3281,1302.
2SK246,J103,2SC1845,A992,MJW0281, MJW0302 all combination works well.
Unfortunately i haven't any 2sk170,j74
BTW what is the max allowed voltage.
Thanks Prasi! Always generous!
Regards.
Nicely Done thimios.. interesting music.
How does it compare to the other low power Class A amps you made..
Prasi
P.S. Who was laughing towards the end? I can see the recording device also shaking a bit😉.
I haven't any other low power class A amplifier but i think that using high efficiency speakers this one will be a monster!Great sound!
No amn't me who laughing towards the end,it is the original recording.To zempekiko tis evdokias (Orxistriko) Manos Loizos (1971)
Do you have any pcb for TO-3 output transistor?
I have some 21193 metal can from a great donation!
Do you have any pcb for the 30w version?😎
