Hiraga "Le Monstre"
The first was all original, great sound but low power.
The second was all original up to the output transistors which were Toshiba
Similar sound slightly different bias needed.
Most recent one was all original except output stage which was Onsemi.
More power on this one very clean slightly colder sound.
  • BOTTOM CU-VIEWED FROM TOP.pdf
  • TOP-SILK.pdf
    TOP-SILK.pdf
Though I got confirmation from 2 builders regarding JFET orientation makes no difference, here is the one with JFET drain connected to BJTs.
regards
Prasi
Hi Prasi
This is the way I usually see the jfet being connected.
Looks like double sided pcb. Is it possible to get the Gerber for this latest edition? I haven’t verified the pcb but I like what you did ! Pls check, there is a red line inside R7.
Maybe I’ll run a small batch, it’s been a while I haven’t send one to PCBway.
Best regards
Eric
Hi Prasi
Best regards
Eric
Hi Eric,
Sure , will share the pdf and gerbers here. The redline indicates that Input ground is to be connected to PSU ground, which is already mentioned on the PCB, so no problems there.
If you have placed many orders with PCBWAY, then you must have accumulated lot of 'beans' . Those can be en-cashed for gift PCBs and projects on their site. Do check out for cool little PCBs and projects!
regards
Prasi
Hello guys,
here are the pdfs and gerbers.
Prasi
Reactions: rubah.ganteng
