Hi Bonsai
A few points that have arisen:
C2/C3/C10 are Wima 150/63 150pF caps recently purchased from US. Small query that the pins are not parallel to the sides (they mount slightly 'skew'). Not what I expect from Wima.
R42 is indeed 1k8
D1 is installed 'as per the PCB silk screen orientation and a quick check insitu shows it's working.
Can't measure C16 installed on PCB but resistance shows as ±32K so it's not shorted.
Some measurements using the Digimess power supply. Voltage doesn't set accurately and can vary (maybe the pot) but it does also have amps out which seems to work OK.
No ZN or 8R dummy load attached.
Circuit board with NJW's 'as is'
Input shorted, ±22V supply and output adjusted to <5mV
Current draw 500 mA. Spurious signal @ 15.3 mHz and 94 mV RMS output as per picture
Input signals at 250mV RMS:
Current Draw of 520 mA @ ±23V
Definite signs of instability on 1 and 20 kHz square waves but signs of over/undershoot
Sine waves at 1 & 20 kHz look 'noisy'.
Check on (Bias) jumper pins 1 & 2 (as per schematic)
No signal applied, ±25V supply:
Pin #1 -1.34V (DVM), Scope: 'No signal'
Pin #2 -219 mV (DVM), Scope: 2 mV, 16 mHz noisy sine wave
250 mV Signal applied:
Pin #1 (connected to 1n4148 anode)
1 and 20kHz sine signals look 'OK' (Picture)
1 and 20 kHz square waves look OK 'Wave shape' (HF roll off), no signs of over or undershoot.
Pin #2 (connected to Q7 emitter)
1 kHz sine looks 'ok' but square wave ('normal shape' - i.e. rectangular) has overshoot
20 Khz sine wave looks 'OK', if somewhat 'noisy', square wave noisy with overshoot.
As requested:
Q3/Q4 collectors joined (i.e. Q7 C/E shorted out):
Input shorted
Current draw 20 mA (!) at ± 19.5V. No spurious signal at ± 17 mHz
250 mV signals applied:
Current Draw 30 mA at ± 23V
Sine 1 kHZ looks 'OK', Square wave has overshoot (Pictures)
Sine at 20 kHz looks 'Wobbly' as does the square wave plus overshoot (Picture)
NB: No signs of cross over distortion
I'll keep on seeing what I can find but looks like the bias circuit has a problem?
Should have taken some more pics but swapping wires, changing settings I forgot to take some
