It should be good with both of them i think both are big drivers.
Personally i dont have any bass under 36Hz but for music its ok.
You can slide this to experience when the speakers go silent
Also you can test your upper hearing drop out
Online Tone Generator - generate pure tones of any frequency
GM
I think you can just Google the
If it is filternet that is the problem, maybe use open vpn
Is this it? Rammstein - Los (Full Band Version) [XXI Version] (Official Audio) - YouTube
GM it's the wrong version. It should be this recording
LOS, a song by Rammstein on Spotify
Yeah, drop out is right, at 74 can barely hear the 12 kHz tone @ 100%.
GM
OK, thanks! There was several to choose from.
GM
Great input
thank you everyone
i am still reading all 20 pages over and over
I learned that my midrange should cover at least 300-3000 hz, it makes it a very important patr in the system
I also learned much about the different driver properties
This is Active and can be changed anytime, therefore its is very good that all drivers have a wide frequency range so it can be modified
The system contains:
Dayton Audio BTR01 Bluetooth-reciever 777 sek
behringer dcx2496le dbx 1 800 sek
Behringer CX3400 Super X Pro 500 sek
Behringer A800 1 600 sek
the t.amp E4-130 2 000 sek
Beyma TPL200 2 pcs 9 000 sek
Acoustic elegance td15m
Acoustic elegance ib18ht 14 000 sek
100 meter cable 2x2.4 1 000 sek
xlr cables and connections 1 000 sek
Cabinets with paitning 1 000 sek
Flexunits 2x4" 4 600 sek
42 477 sek = 4 835,20
leftovers, maybe they can make a system for the spa in the basement =) I also have 2 x eminence kilomax 18 since many years
2 x de250 2000 sek
2 x horns 1000 sek
2 x visaton ti100 2000 sek
2x15" somtak 1000 sek
boxes 500 sek
6 500 sek = 739 usd
Value for money or not?=)
Everything should be here mounted ans playing in 2 weeks
thank you everyone
2 x de250 2000 sek
2 x horns 1000 sek
boxes 500 sek
6 500 sek = 739 usd
Great tune generator
I dont know if i am in phase:/
The oscilloskop is Hard to trust
I take the easy way out with speakers and go full range drivers.
Saves money and weight with traditional LC crossovers.
What oscilloscope would you use?
Well since the volume control came Up i figured it might just as well have tubes.
But i got it
Also i think the Common use of preamp is just before the amp and that would have been 7 channels?
Now to give the crossovers a better signal could be a Good thing, checking out options
But i got it
Hello again 🙂
I am expecting delivery soon for the drivers.
In the meantime
Time to check out the electronics.
I use a bluetooth Link for the moment because i really like to have the system connected to Google home.
Do you guys have a suggestion how to connect the system without bluetooth?
From my knowledge
Option A.
Argon is introducing a Google home unit with dac that Will be connected with cable to DSP/filter
Maybe this Will due for a PRE amp/ volume control also?
Option B.
Find another Google assistant device with cable connection and connect it to a PRE amp
In the meantime
From my knowledge
Option A.
Option B.
You should ask in the PC section of the Digital Line forum here, perhaps there are people and developers aware of domotic and devices compatibilities...
There are multimedia distros on Rpi that can rule dacs but I don't know about compatibility with an Alexia/Cortana/HeyGlouglou/etc device copatibility without a standalone channel on a pre... but do you really want a mic in your living room !
15th October 2020 09:17 PM
I was trying the attachment feature to show the progress but i guess i will try again. In a moment
Very happy with the flex unit, still waiting for the acoustic elegance drivers
diyiggy
No problem we only talk business in the basement and not around the table ��
diyiggy
- Help to choose the ultimate midrange driver
