Help to choose the ultimate midrange driver
Great input
thank you everyone
i am still reading all 20 pages over and over
I learned that my midrange should cover at least 300-3000 hz, it makes it a very important patr in the system
I also learned much about the different driver properties
This is Active and can be changed anytime, therefore its is very good that all drivers have a wide frequency range so it can be modified
The system contains:
Dayton Audio BTR01 Bluetooth-reciever 777 sek
behringer dcx2496le dbx 1 800 sek
Behringer CX3400 Super X Pro 500 sek
Behringer A800 1 600 sek
the t.amp E4-130 2 000 sek
Beyma TPL200 2 pcs 9 000 sek
Acoustic elegance td15m
Acoustic elegance ib18ht 14 000 sek
100 meter cable 2x2.4 1 000 sek
xlr cables and connections 1 000 sek
Cabinets with paitning 1 000 sek
Flexunits 2x4" 4 600 sek
42 477 sek = 4 835,20
leftovers, maybe they can make a system for the spa in the basement =) I also have 2 x eminence kilomax 18 since many years
2 x de250 2000 sek
2 x horns 1000 sek
2 x visaton ti100 2000 sek
2x15" somtak 1000 sek
boxes 500 sek
6 500 sek = 739 usd
Value for money or not?=)
Everything should be here mounted ans playing in 2 weeks
Well since the volume control came Up i figured it might just as well have tubes.
But i got it
Also i think the Common use of preamp is just before the amp and that would have been 7 channels?
Now to give the crossovers a better signal could be a Good thing, checking out options
Hello again 🙂
I am expecting delivery soon for the drivers.
In the meantime
Time to check out the electronics.
I use a bluetooth Link for the moment because i really like to have the system connected to Google home.
Do you guys have a suggestion how to connect the system without bluetooth?
From my knowledge
Option A.
Argon is introducing a Google home unit with dac that Will be connected with cable to DSP/filter
Maybe this Will due for a PRE amp/ volume control also?
Option B.
Find another Google assistant device with cable connection and connect it to a PRE amp
You should ask in the PC section of the Digital Line forum here, perhaps there are people and developers aware of domotic and devices compatibilities... 🙂
There are multimedia distros on Rpi that can rule dacs but I don't know about compatibility with an Alexia/Cortana/HeyGlouglou/etc device copatibility without a standalone channel on a pre... but do you really want a mic in your living room 😉 !
There are multimedia distros on Rpi that can rule dacs but I don't know about compatibility with an Alexia/Cortana/HeyGlouglou/etc device copatibility without a standalone channel on a pre... but do you really want a mic in your living room !
15th October 2020 09:17 PM
I was trying the attachment feature to show the progress but i guess i will try again. In a moment
Very happy with the flex unit, still waiting for the acoustic elegance drivers🙂
diyiggy
No problem we only talk business in the basement and not around the table ��
