GU-81m tube amp schematics???
How much power is expected ? What is the impedance of the OPT ?
Here is a link to a valuable site with tube characteristics and documentation:
electron Tube Data sheets - G
Specifically, the GU-81 that I am using is this one:
http://frank.pocnet.net/sheets/175/g/GU81.pdf
My quiescent point is at Ia = 250mA, Ua = 1400V, U_s2=600V.
In my new "S3_HV_UL" topology, the crazy U_s3 = 1400V, connected via OPT to B+, but with an S3_Anihilation_Limiter = 1000 ohms / 20 Watts.
Without any such resistor, the S3 tends to melt / explode / evaporate / disintegrate / disappear. Slightly dangerous. Thank Goodness that I used a variac to test that initially.
Very nice. Classical but nice. The Power supply is familiar. Similar to the one I have, slightly different configuration, but same topology. So you suggest to go for a dual symmetrical voltage feed for a simple Cathode Follower pair ?
Hmmmm ..... I think I like it.
The more so that I have a few additional power transformer tappings which I could use for this ...
Ziggy
Yes , I think that DC coupled CF triode drivers bipolar supplied is very good solution from many reasons , one reason is that you can easy drive OPS in A2 /Ab2 class of operation without to raise significantly THD factor , you can even consider another types of tubes for drivers as 6V6 , GU50 .....
And I think that your expectation for only 100W of output power in A class region is to modest , my rough calculation says that will be around of 250W .
Here is the quick concept draw , ...
I am trying to envision potential "disaster scenarios".
a). If the driver tube in wiggles / gets a mis-contact in its socket, then we are on the safe side, as the GU-81 grid gets the -200V on it's grid and is cut off ... correct ? The transformer will be saturated by the current of the other tube, but that is not in itself a disaster, is it ?
b). If the bias setting pot fails on the driver tube ... like a slider miscontact ... that smells like potential disaster. Grid is unbiased, the driver tube starts conducting heavily, GU-81 grid gets a big positive bias and we are in trouble.
But I think that If I add an additional fixed safety resistor, an "anti-pot-failure" resistor, and place it between the slider of the pot and the negative voltage end of the pot, then we are "safe" yes ? In the case of slider mis-contact, the driver's grid gets a much higher negative bias, the driver shuts off, and consequently the GU-81 also shuts off ... Correct ?
For any worst case scenario in my schematic you have there standard HV slo-blo fuse in 1,2KV B+ supply line , and two 10R/10W resistors in GM81 cathodes circuits , so if OPS from some reason draw some abnormal current ,or if OPT fail , something from those two elements will blow and OPS will be protected .
I made some quick LTSpice simulations with push pull circuit.
The operating point was: Ia = 238 mA, Ig2 = 65 mA, Ug1 = -127 V, Ua = 1.2 kV, Ug2 = 600 V. OPT series resistance was 200 ohms anode to anode.
I varied the OPT impedance between 5k to 8k2. The performance in general and linearity seems not to be sensitive for load impedances I used.
Some sort of max. output power is about 350 W and THD then is from 3.5 % to 4.5 %. Below 200 W THD is about 1% to 1.4 %.
The screen stoppers should be as small as possible (<100 ohms). These have strong effect to available output power.
I don't see any reason for cathode follower drivers. G1 voltage stays allways far from grid current area.
It is always good to simulate an new schematic.
I am halfway the building proces of the SE version. Below a picture of the power supply. I tested already the heater supplies. now i am buiding the HV supply and the chassis.
How about the filaments ?
Speaking of output tube filaments, which require 12,6V @ 10,5 A, what would you consider as the preferred option:
a). A toroidal transformer with 12V output and sufficient current capability,
c). A plain vanilla SMPS, of type MeanWell SP-150-12
d). As c). but with additional CLC, where C=150000uF/16V || 1uF foil || 47nF and L is a few bifilar turns CMC choke on a ferrite core
e). A toroidal transformer, rectifier, filter, and then Voltage source
f). A toroidal transformer, rectifier, filter, and then a Current source
g). A toroidal transformer, rectifier, filter, and then a Voltage source, followed by a Current source.
h). None of the above.
Are you asking me ?
I am asking Koifarm how he plans to do this.
I do not have too much practical experience with direct heated tubes.
I have built one 811A and a 813 SE prototype with AC-filaments.
I got > 65 dB S/hum, so propably I would try the same principle.
I think playing with current sources is useless.
See post 63 for the schematic.
I use cheap chinese SMPS for the heaters in several direct heating amps. No hum or noise at all. at the moment i use a fu13(813) amp to.
I run the smps with NTC resistor to slow down the startup current.
