Goldmund Mods, Improvements, Stability
Shunt voltage now reads 5.023V.
Here is the simulated input rejection. Several volts input ripple should not hurt, but if so bootstrapping R6 is a good option.
- keantoken
Little better around 100Hz. But significant in %. Especially at 20-30Hz. My model gives 200uA with Rs1k2. The main question remains if it will shrink drift. You will see in practice with OS's fets.
See ya.
Getting into the uA, the Ib of Q2 becomes important. Simulated is 36uA. Simulated drift is 116mV/C. Beyond a point, it looks as if the drift will simply result from chaotically combining tempcos of Ib, Id, etc.
Also, increasing bass performance must also increase start-up delay.
Shunt voltage now reads 5.013. It looks as if the voltage is stabilizing. I will leave it on until I wake up.
Now I'm REALLY gone,
- keantoken
Which single component do you think is temp. sensitive the MOST?
For instance if it where the cap, maybe back to back caps of opposite temp coefficients would be helpful. I did that once in a cold weather environment timer circuit once.
I think the most temp sensitive part is the CFP driver; it's base emitter junction affects the voltage divide function of the sensing circuit. The jfet pulls constant current, sure, but the tempco is not the same as the driver.
I've been thinking hard on this. There has to be another way.
What about returning to the 68K/470R solution, removing the jfet, and trying this:
#1 Add 300mV of degeneration to the CFP driver to elevate its base potential,
#2 Remove R2 470R, replace with a diode wired npn in series with a resistor.
I don't have time to figure the values just now, but if the diode wired npn were thermally coupled to the driver it would track, and this would preserve all currents and thus the output voltage. A guestimate for R2 would be 220R.
Hugh
Hugh, the degeneration will "mirror" the slave's Vbe and we'll be introducing another tempco. Simulated to check, it doesn't help.
It looks like the Jfet is the best bet.
The shunt was sitting on a larger heatsink, and I noticed that output voltage would increase or decrease depending on whether it was sitting flat (by about 200mV). I have some cardboard under it now and output voltage is now 4.957V.
Think winter time. Someone opens the door, cold air comes billowing in. The draft will increase the reg's output voltage. Using a TL431 would also allow us to increase R5, for better bass.
- keantoken
