OK....so the reason for Germanium is that they have something to offer not possible with tubes or FETs?
Certainly Germanium offers some outstanding features:
-highest noise
-highest instability vs temperature
-lowest bandwidth
-worst availability of all😀
-highest noise
-lowest bandwidth
When I was studying I also learned than going from Germanium to conventional transistors was a big technical step forward. But still with tubes some very fine oscilloscopes was made with sensitivity in uV area. So maybe going from tubes to Germanium was not a very big technical step forward other than cost, size and heat dissipation. MTBF is probably also better with Germanium 🙂
Do you have any Germanium power amps noise/distortion measurements to look at to get an idea how it looks?
-highest noise
-lowest bandwidth
Don't forget leakage.
I have a preamp with JFET transistors . And there is a power amplifier with MOSFET transistors . I like them . But that doesn't stop me from also loving the sound of germanium preamps...And I'll probably also make a power amplifier with germanium transistors ...OK....so the reason for Germanium is that they have something to offer not possible with tubes or FETs?
Some years ago I "cleaned up" in some old electronic components and a lot of these types were trashed:
OC 47, Tube OC47; Rohre OC 47 ID38188, Transistor
Also some germanium power transistors which was factory packed in pairs. They where quite large in size. Maybe you would have liked them.....
The small black coated transistors like OC47 went very light sensitive if the black coating was removed. Think this "feature" was utilized to convert them to a kind of photo transistor.
I have germanium transistors made in the USSR . Including - with a stamp of military acceptance . There are many more in Russia . Enough for the rest of my life )))))...
In the 70s,many radio Amateurs in my country had difficulty acquiring certain types of radio elements . And there were cases when photo-transistors were made from germanium transistors . Carefully cut off the upper part of the metal body of the transistor . It worked .The small black coated transistors like OC47 went very light sensitive if the black coating was removed. Think this "feature" was utilized to convert them to a kind of photo transistor.
But Germanium transistors are not made anymore in Russia?
Are there also special quality of the 6c33c triode or were they all made for military use.....for the MIG25?
EMP? It's NP for the 6C33C-B Tube | thetubestore Blog
I like germanium expression with music. What can I say, I still believe in FETs being friends of mine, having that "over the top, over the top" presence, in back of my head. But germanium just fully employs itself, being 360° present. Si BJT types are nice, but just too active in a way for me. I am not allergic, just paranoid. They are in back of my head, also in front of me, already gone and still here. It is okay, just makes.it very difficult for me to use my ears to create this weird cinema of mind and soul. Way too sober for me, I just cannot take it often. That we are sober. Clinically cynical. Guess I am, often. And it's just reflecting too strong with Si BJTs. I have never tried those SiC and stuff tho.
Germanium transistors were produced in the USSR up to and including 1991 . I have these transistors made in 1991 . In the USSR, the release date was usually indicated on the transistor case ( if the transistor had a metal case ) ......Lamps and transistors for military products were more strictly selected by parameters . And on the body of the element was a stamp of military acceptance . Such elements are considered to be more reliable . The 6c33c lamp was produced in large quantities . I think that the rumors about its development specifically for the MIG-25 are greatly exaggerated .But Germanium transistors are not made anymore in Russia?
№211 More than 10 clips of different GE amplifiers with diagrams and discussion. Mostly Lin options. There are no NFB. P=10-15w, THD=0,05-0,5%
Усилитель Иванова (3) Радио 1970 2 - YouTube
Новые видео канала Bayu 63, Смотреть онлайн
US $68.05 6%OFF | The pure class A single-ended germanium tube preamplifier board with choke load output has dynamic mellowness
The pure class A single ended germanium tube preamplifier board with choke load output has dynamic mellowness|Transformers| - AliExpress
Good idea? Looks yummy
The English is pretty good ..... no bile cows etc.
I may buy one when I get back to the UK next month.
Andy
US $68.05 6%OFF | The pure class A single-ended germanium tube preamplifier board with choke load output has dynamic mellwness...Good idea? Looks yummy
Look at last photo ? See front panel with " Power amplifier " ?
Not clear 🙄
Transistors inside are not germaniums..take care..
DIY something 🙂..not buy ready made without schematic
You are being deceived!
There is no scheme! The parts used are different!
2SB337 PNP Ge - isc Silicon PNP Power Transistors 2SB337 DESCRIPTION ·Low Collector Saturation Voltage- : V = -0.29V(Typ.) @I = -4A CE(sat) C ·High Power Dissipation
2SB337
- параметры, поиск аналогов, даташиты транзистора - Справочник транзисторов
·Designed for audio frequency power output applications.
3AK34B high-speed power switch tripolar tube.
2SB337
- Germanium investigations
