Yes, there are more boards, kits and transistor sets available. If you are in the EU or GB, you will need to purchase via Reverb link in my signature. Let me know if there are any questions.Hello Tea-Bag. Are there any more kits available?
Just placed my order for a full kit.
I Will let you know my feedback when possible.
Regards from a Spanish Diyer !
Antoni
Barcelona
Antoni
Barcelona
Group buy for these boards end in one week on 2-27. Please see links in my signature (not available on mobile) or private message.
Group Buy will end tomorrow evening. Please sign up in spreadsheet linked in signature (not visible in mobile, sorry) or private message me with your email and where you live, to determine next steps.
Group Buy ends tonight. Please sign up in spreadsheet linked in signature (not visible in mobile, sorry) or private message me with your email and where you live, to determine next steps.
please add me inGroup Buy ends tonight. Please sign up in spreadsheet linked in signature (not visible in mobile, sorry) or private message me with your email and where you live, to determine next steps.
PM sent
I plan on getting the bottom plate CNC cut ... is it possible to get the exact mounting hole positions of the PCB's ?
I do believe I have killed my DCG3 build. I would like to buy a DCG3 board and full parts. I did not kill the I-select or power supply yet.There are boards and kits currently in stock.
Sadly, the board I built will go to salvage/parts.
Russellc
Whoops, I put this in the phono pre thread. I did not kill that one, it is playing beautifully. Tea, I will send PM.
Thanks,
Russellc
Thanks,
Russellc
I just selected the 62db gain for my MC cart.
Having left idling for 3 hours and adjusted the TP for 4.00V
However, I realized that the TP voltage is hard to lock on to 4V as stated in the manual.
It can go as high as 5'ish Vdc when powered up cold and back down lowered to 3.5 'ish Vdc later when operating for a few hours.
Is this normal?
Or did I do any steps above wrongly?
Other than the above, the phono amp sounds fabulous!
Is this normal?
Exaggerated test point DC drift in MC modes is normal. Especially in max gain LMC. That's due to the dual 2SK369s lively thermal behavior when run in high Id mA. Strong drain current bias and small value source pin resistors are beneficial to achieve lowest noise spec in MC modes as most needed.
Much less T.P. drift is noticeable in MM setting because a single 2SK369 and a much higher value source pin to ground resistor are selected. Id and gain go down as a result. So the local DC & AC feedback control on the input JFET goes up.
What MC cart you use?
In any case your phono build works as expected. Happy to know that you like its sound!
Nice cartridge with musical character, I also have one in my collection (R version). You like it better than your Nagaoka MP-150?
Nagaoka MP150 is punchy, musical, and seems to handle transient better. Vocals are more localized.
DL103 is more mellow, with airy vocals but less punchy.
My first time trying MC, surprised to see MC mode is even quieter than MM mode in the background.
With tonearm lifted, i can crank up vol to max and hear some hiss, i can't do that when in MM mode!
I will probably ignore the Jfets temp drift and just enjoy the music.
Thanks Salas for your great phono design!
I've collected most of the necessary items and I'm about to start building tape head pre with these boards. Salas had posted some tape head circuits here: https://www.diyaudio.com/community/threads/preamp-for-reel-to-reel.222113/#post-3213006 Those circuits use 2sk170s for the first stage amplification and the ufsp uses 2sk369. Is someone able to calculate the db gain of the tape head circuits so I can set the proper gain in the ufsp? Or, better yet, provide a description on how to calculate the value? I've searched and think I have a formula, but I'm not sure how to get the gm value and the the db numbers I get don't add up to a sane number
Just a notice.
The Group Buy will be closing on April 2 2023.
To those who signed up on spreadsheet, and private message with details has been sent.
For those who I have email address, invoices have been sent.
Please let me know if there are any questions prior to the group buy closure time, and pay accordingly.
- Group Buys
- GB Group Buy Salas UltraFSP RIAA
