Frugel-Horn Mk3
For making FH3 enclosure removable, for adjusting damping or changing drivers in future, can we have the whole front baffle as removable ? (have a thin wood strip all along the internal lining of the front part of the enclosure with some T-nuts at the back of them and then screw the front baffle over it )
Or have half of the front baffle fixed on the enclosure and top half removable as above with screws and T-nuts on thin wood strip on interior of the front part of the enclosure.
Or its enough to got with a regular rectangular super baffle without the side wings for adjusting the damping.
Depends in how well designed the Voigt is (ideally an ML-Voigt).
dave
any thoughts on this one? I find it interesting with the downward/floor firing exit allows you to essentially tune the size of the exit to your liking for any given driver used... Might it have better bass esp with room corner placement?
The shape of a Voigt pushes the harmonics down in freqiency making them harder to kill. Mass-Loading really helps, from there driver position and the damping.
A poor one will have a ton of ripple, a well done one nice.
To explore the challenges of getting damping right with no mass-loading, see the challenges that BIB builders have had.
dave
Reactions: GM and gnat_leader
dave
so in general then forward exit like this is better?
