FirstWatt J2
Yes, ZV4, page 3:
http://www.firstwatt.com/pdf/art_zv4.pdf
"Digikey doesn’t have 5 pF caps anymore, but I have listed 10 pF
parts in the parts list. You can buy 2 and put them in series to form
a 5 pF capacitor. Alternatively, you can twist two fine insulated
wires (like those used in wire-wrap construction) together at a
length of about 1.5 inches and get about 5 pF. This technique
has the advantage that you can start out too long and trim it with a
pair of scissors while watching the square wave of the amplifier."
Finished it less than a hour ago.
Still processing it.
It's the one with the blue button on the front.
I'll take more pictures when I put it back on the bench.
The matched quad p-ch jfets were 11.4 idss and the ccs jfet is 10.4 idss.
Is that a big problem?
When setting the offset, I had to make micro adjustments as the offset would jump in large increments. The trimmer is 10k. Used four semi-south R100.
Listening to it now and beginning to see what all the fuss is about. 😉
It's working. 🙂
First, Patrick thanks for putting this together and for Mr Pass for letting it happen.
Also, I very much like the screw connections. Negates the need to find odd connectors and it's a solid connection.
Really happy to finally getting to hear a J2. Sim, clone, exact copy or not, doesnt matter, it is a special amp.
Thank you Zen Mod for the trimmer value, setups like a champ! 😀
The offset was dropping as the amp warmed up. Nice!
Thank you,
Vince
