Filter brewing for the Soekris R2R
Finally readjusted allpass filter for hopefully satisfy wider group of people. It’s based on one of my early filter, so should be ok but verification is needed.
Some more explanation about allga filters family.
F4 to F6 filters stacks are made identically just with small change in FIR2 stage filter which is new 64 coefficient filter.This small difference allow to make adjustment of sound presentation according to preference.
Second thing that is special in allga family is magnified distortion adjustment with volume. If we set 0db on dac we could get over 5% THD. Lowering volume to c.a -6db on dac almost cancel that effect, so we have 0 to -6 db to adjust harmonics to preferred level.
There is FR with elevated high frequency ca 1.5db
F7 filter is NOS/NewNOS stack for “classical” presentation(volume level works as usually:)
Anti aliasing for all with IIR filters.
I wanted to try this package on my DAM1941 assuming that the 1021 filters work here as well...welll...error message: "Incorrect Image" when trying to update...is there a pure NOS-Filterpack for 1941 ? IDeally with the first filter being NOS as my friend did not wanted to invest into the font-panel...so he has only one filter, the first one all the time.
Is the difference not the FPGA? In stead of the Spartan there is a Lattice in the DAM 2541
You don't need to send "update" command after downloading the filter, just exit and / or toggle filter. You can also change and save the default filter.
Thanks for clarification...just found as well TNTs comment that the Dam1121 manual is more selfexplaing...when I want to select a new default filter...is this done with the run time command:
Fx Filter Type, 4 = linear, 5 = mixed, 6 = minimum, 7 = soft
So, when I power off and power on...will the dma1941 remember this new selection as the new default ?
TNT
Joined 2003
There are two ways of changing filters - just to complicate things for the user... ;) Another problem is that the designer has not defined enough terms and concepts to describe the handling in a stringent and pedagocical manner. This is also probably the reson why so many have questions about it.. but Sörens un-paid support staff is here 24 hours a day - yes sir :) isn't it conviiiinient... Only one out of the two modes of the serial interface is named. I will below use Connected and Unconnected to describe the handling.
- When you don't have a promt, i.e. the serial connections mode directly after power on - lets call that "Unconnected" mode - you can enter e.g. "F5" and the DAC will change filters to F5 immediately. But it will not be permanently stored. If you want to make it survive a power cycle you need to use an other command in "Connected" mode i.e. when you see a promt - you get that after entering +++ in Unconnected mode. In Connected mode you use the "Set" command to do permanent changes - it will be instantly effectuated - see the "Manual".
To get back to Unconnected mode from Connected mode, use command "Exit".
Ahhhh, great, now I got it...i think..
So, procedure will be:
  • Power on and have serial connection, wait for status message
  • type "+++" to get into uManager
  • type "set filter=minimum"( for F7 as an example)
  • type "exit"
So, i will start to learn what you guys did in the meantime, I think i used TNTs filterpack amd liked the NOS filter within best sofar...more direct than the rest...I worked on many other topics, but niw the resolultion of my system comes to a point where the filters will be even more audible...
I have a question again, sorry to bother you...I bought a dam1941 when it came out, updated it to 1.23 and put the TNT/spikestabbern version on it with f4 the original Soekris Filter and F7 the NOS i likes best sofar.
Now, I bought for a friend another dam1941 like a year ago, not sure if anything has changed.
  • i uploaded the NOSversion of gumisb first on it...and found that some of my music is highly attenuated like -12db or more...only when playing 96khz/24 files..... far too low to enjoy music, i need the voltage gain.
  • so, i simply put the old TNT/spikestabbern version (1693) on it...same issue !!! I never had that issue before with my old own Dam1941 where this exact filter pack is playing for years
  • So, i downloaded Soekris original filter, back to delivery status...now we have same volume, no matter if 96khz or not.
  • So, i downloaded TNT/spikestabbern again setting again: Same issue as before...highly attenuated, but only at 96khz/24...
My old dam1941 where I had not the gumisb version on does not have this issue...I suspect there is a setting which has not been cleaned when uploading firmware /soekris filter pack 1.23 ?...my suspiscion is because my Setting F7 as default as well survived the firmware update...So, düthe DAC is not completely resetted to delivery status...
Hello I was trying to do a dsp room corection in fir1 by rephase on 4k tap filters(thanks Marcin for helping me start) Of corse i have don room measurments by rew aqustic. And i want to do something with lowest room mods. Beacuse i dont have no more room for rezonators ant bas traps(rest of room have good quality pasive aqustic. So i was using dsp room correction in roon audio system, but playing fromm cd transportmdont have this correction. I have put corection in rephase,generate impuls and what i get? Red line shows me that i have olmoust nothing. I have done skr file and try this filters. But nothing big i have heard. Inn roon correction when i put some corrections 50 hz.. 68hz.. and more i have get good bas , very good. Can any body help me? Very thanks.
TNT
Joined 2003
When you hit the generate button in rephrase you see a red trace showing up - this is what you in the end will load. This red trace can differ significantly from what you have dialed in due to that 4k isn't so much capacity. Keep track of that and see what you actually got. Alterations at low frequency is particular capacity demanding.
