Film caps in powersupplies
hardly of any relevance
yes, in cases of most benign use
had on bench most expensive gadgets, Yore Japanese, with all sorts of problems simply because they didn't use split washers for mounting TO220 on heatsink, screws and rest being proper steel hardware
with time plastic bushing gave slightly up, resulting in lesser thermal contact to heatsink, so plastic bushing gave up even more ....... ending in scorched solder and traces
anyhow - I don't care, everyone is doing it to own liking
I'm usually screaming only when I see major issue with safety regarding mains
Rather than plastic bypass caps, I thought you were going to ask about using only film caps in the power supply. I read about doing this years ago in a Lamm preamp:
https://www.stereophile.com/content/lamm-industries-l21-reference-preamplifier
but can afford neither a Lamm preamp nor DIY all film-cap power supply. Given that people who can afford it — for example, Pass Labs reference preamps — still don’t do it, I figured it was a 1% improvement.
Still, I’ve wondered… has anyone here done the experiment?
Technically not a good idea. You want some loss in your decoupling caps.
If they are lossless, any hf junk coming in on the top pole would go unchanged into the ground rail, which generally is a bad idea.
Lack of any losses is also the reason why some voltage regulators oscillate with a film cap on their output, but not with an elcap.
If you read the datasheets of voltage regulators, very often they give the minimum ESR (equivalent series R) for the final decoupling cap, usually somewhere between 0.1 and 2 or 3 ohms.
Same with the superreg - many builders ended up with a power oscillator by not reading the building guide and putting a super duper $$$ film cap at the output.
Jan
Reactions: gorgon53
I had a 40 year old Conrad Johnson Premier Three B tube preamp with only filmcaps for PSU duties.
The first prototype Quasimodo was slapped together on a solderless breadboard. Since I had no 1-ampere gate driver ICs at hand, I just used several CMOS logic inverters in parallel. And since I had no power MOSFETs, I just used three junkbox 2N7000s (TO-92 packaged) in parallel.
You, yes you, could do the same on your solderless breadboard. Today.
There is also a stripped-down, lower cost variant here on these Forums. Search thread titles for the word Cheapomodo .
_
I once had a pair of Threshold S/1000's (SA/1 hardware but then in bridged mode to get 500 Watts at 8 Ohms) that had a hum over the speakers.
I cleaned all GND connectors and surfaces with a contactcleaner going to this metalplate and the hum went away. Just simple as that.
Pray tell us why this procedure could be audible?
As mentioned, the biggest issue with metal plates is corrosion and conductivity, especially on the ground side. As long as this is taken into account into your grounding and earthing scheme, and proper maintenance is done, things should be fine.
Same here, what about the metal case, serving as ground? What about copper plates?
The case serving as ground is a nono for decades. Just clarifying to separate it from earth. Even though we still see it in "authentic" circuits like guitar tube amps.
Brass looks great also ;-)
Brushed brass is a weird choice for a high current amp. It has many times lower conductivity than copper, the brushing lowers the contact surface, and if you do something like use it for ground and allow big return currents to flow across it, you may have noise or hum.
I have an ASC motor run and Solen PP caps in my outboard tube amp PS. I can’t speak to any advantages in terms of sound quality, but the caps will undoubtedly outlast me.
If you can find 30000uF film caps, I strongly encourage you to use them. :smash:
Now I’ll wait for a certain curmudgeon to enter the thread to deride you for even thinking about recapping it at all. 🍿
