F6 Illustrated Build Guide
Those BPR resistors look similar to the Fukushima/Futaba MPC resistors that some builders have used as source/emitter resistors. I don't expect any issue with using them.
The only thing I would caution is that since the BPR are radial with 9mm pitch, they don't physically 'drop in' the R1/R2 spots on the PCB and you need to be careful bending the leads to fit them in.
Have fun.
Reactions: pestoman
I've been banging my head against this problem, hope someone can point me in the right direction...
I've got one channel installed and am trying to set bias and offset. with bias set to 0 volts, I can get offset to zero no problems. However, once I set bias past around .28v, I can no longer decrease offset to zero. As I increase bias, the offset seems to hit a floor and will no longer decrease. There are plenty of counterclockwise turns available on P1, but turning has no affect on the Offset. This effect increases in severity as I increase bias. Once I set bias to around .5v, the offset is also around .5v and will not go down even as I make several turns counterclockwise with P1.
Can someone point me in the right direction on how to troubleshoot this? I was very careful to check all resistors when I ordered the parts, and I double checked each part as I installed everything. I am planning on installing the other channel circuit board this afternoon, just to see if it exhibits the same behavior.
Voltage across Z1 is 4.5v, Z2 is 5.9v. Q1 and Q2 read 4.5v. Temp on the MOSFETS is around 39c
Thanks in advance for any tips!
@jbholman56 : 4.5V for Z1 is kind of low even if it's a 5.1V zener. One possibility is that's it's current starved. Can you please answer ZM's earlier question about the resistor values you used for R7 and R8? (I'm referencing the schematics from page 1: https://www.diyaudio.com/archive/gallery/data/500/F6_DIY_SCH.gif ) Also, can you confirm the Z1 and Z2 values you used? (You mentioned a 5.9V measurement for Z2)
For an explanation for what Dennis is looking at, read post #27 by ZenMod few years back. The general recommendation has been to use a smaller value resistor for R7, R8; for example 3.3K ohms. If they are 10K ohms, then the zeners are current starved.
Direction of bias pot is immaterial as long as you know which direction to turn them. If you are watching the voltages on your DMM, you know which way to turn them 😉 .
Best,
Anand.
I will replace the zener with a known good 5.1v, as well as reverse the direction of P2. if that does not fix the issue, i will research the zenmod link provided and revisit those resistor values (I am using what was in the BOM). Thanks for all your suggestions, i will try this tomorrow morning and let you know the results...
Thanks again, Brad
Reducing the value of R7 is a good idea to increase the current, but I do not believe the zener is current starved if R7 is 10k. If the PS voltage is 23V and the zener is current starved (not conducting), the voltage across the 5k trimmer would be closer to (5k/15k)x23V=7.7V, not the measured 4.5V.
I think it is most likely the zener has a voltage tolerance of of 10% and the zener installed is at the lower end of the allowed tolerance. So replacing the zener is likely still required.
Reactions: Dennis Hui
I replaced the zener, and am now good to go! I measured the replacement zener before installing, and meant to post measurements on both the old and new, but I cannot find the old one. If I can find the old one I will measure it and post what I find out.
I will read up on the R7 issues you mentioned before proceeding with installing the second channel, in case I want to try those suggestions.
Many thanks to everyone! Brad
