F6 Illustrated Build Guide
Um, there's a 62.5R/m wire from German manufacturers "Block RD" on the Conrad Electronic website (part no 422420) - don't know if it's Isotan or Manganin (0.1mm dia) or what but worth a look.
Some of the eBay people aren't too good with queries but try sending a follow-up - I found "lci-electronics" in Bulgaria to be good guys, but not sure what's available.
"evek.de" in Germany still make insulated Mn wire for the marketplace - I didn't know Harris still supplied insulated Mn wire on the eBay, but not cheap. I think there's also a company in Wales (UK) that sells this product by the metre but a hefty surcharge.
Finally... I'm done
Hi guys,
it's been a while since my struggles with my F6 and your great help.
Just wanted to show you my final results.
I'm very very happy with my F6 and the outcome of my chassis.
Only thing that's a bit sad.... the guy who did the anodizing of my covers messed it up.:crying:
Thank you all very much 🙂
Reactions: kaan
F6 Hum
I have been asked to take a look at this F6 built by a third party. All the PCBs are from DIYaudio store along with the jfets and mosfets. The Transformer is a Zero 500VA 18-0-18 with various other secondaries for the Soft Start and and speaker protection. The Wiring (including the Chassis and PSU grounding) is as per spec. I have incorporated the 3k3/LED mod to enable the bias to be set at the spec 0.5mV the offset is less than 10mV steady state and warms up as it should. I couldn't get this before with the 5.1v zener.
Al the components look genuine items and purchased via Mouser/RS and or Farnell I believe.
Buggered if I can find the hum issue (not vol dependant) The hum rises as the amp board 1000uF cap charges and we get output.
I have now separated the AC (top left) from the DC. Initially they were all tie wrapped together in a loom. The Hum is better by some margin now by doing this.
I have built many F6's and other Pass First Watt clones without this issue.
Any help appreciated.
TIA
… and the diodes directly opposite the transformer doesn't help either
I doubt that you can do it but if you (re)moved that front meter (or maybe change it) and stand the transformer vertically (with a bracket), then move the rectifiers and caps forward, away from the signal transformer (ZM), this might be enough - or add the transformer shielding as suggested (pico) - this might save you adding a separate case.
I don't think you could mount the rectifier board on top of the transformer but worth a try
Also, suggest you twist the wires, as AndrewT used to emphasize, and shorten them where possible.
Hello, this is my first post here.
Inspired by the F6 Illustrated Build Guide from 6L6, I ventured into this project.
Only the power supply board I used is different.
At the output of the board, measured between + and -, there are 50 V DC on each side.
Measured between + and gnd it is 25 V DC.
Measured between - and gnd, it is also 25 V DC.
In the diyAudio Power Supply Circuit Board v3 illustrated build guide I read that this is ok.
My question about my safety:
Can I now connect the F-6 amplifier board to the supply board and start setting BIAS and OFFSET as described in 6L6?
I would appreciate an answer very much.
greeting
Dieter
