F6 Illustrated Build Guide
Yes , thank you.. am aware of the DC offset trim.
From past experiences Bournes' are shipped at ~midpoint.
ALL is soldered in place. All that's missing is 120 Volts.
From Vssa experiences, setting bias/Ddc offset shouldn't be a problem.
I hope 😉
Unless I've bungled a soldered connection.. somewhere.
There is Always room for a screwup.
Second what Russell has posted. I am fairly new to DIY, though built many a Heathkit in the day. I have mostly stuck with the DIY Store products. All of my transformers have been Antek, the critical transistors from the chap in Israel, Alweit is his Ebay ID. The come closely matched and are the real item. Cases have been bought through the store also. Parts mostly from Mouser and Digikey with a few from other vendors as needed. I have also tried to shop with the various merchants that post here. Apex and SoniCraft are my two favorites.
Octopart is a great website to see who has what part in stock. And Russell is right follow the guides and your Pass amp or preamp will work. Thus far I have built two F4 and one F6 amps along with a BA-3 preamp, using parts from the above vendors. They have almost always worked first time, yes I have made a few errors, corrected them and now I am enjoying Nelson Pass sound.
That would be higher than I would want to go. We are talking about 32 or 33 V rails after rectification. Brave souls would try it I am sure. If my memory is correct 30V is about as high as most go. More technical savvy members can do the numbers for you where I am just speaking from what I have read.
Built My light bulb tester gizmo using a 60 w bulb, disconnected power wires from PSA to amp boards.
Bulb lit bright then a second or 2 later dimmed to nothing.
Wee green Leds lit up nicely.. 24.7 V from either side of the PS outs.
Seems good to go, albeit the wee green leds stay lit for ~15 mins after power off.
So.. in setting bias efforts..what does measure across the 0.47 resistor actually mean?
Meter's Alligator clips to either end of the resistor.. Or? 😱
Yeah can use alligator clips why not and congratulations with your build.
What psu board do you use, how much capacitance?
It will definitely take a while when your caps are discharged, I got a couple of minutes for 30000uf per rail so might be longer for 60000uf))
Sent from my ONE A2003 using Tapatalk
Ermmm!?
Right channel under test/running with 60 w light bulb at medium brightness
Using the 6.2 v Z and 3.3k resistors (dunno about the Ohms from Memory only) but read/followed as Zen Mods suggestion.
Bias trimmer runs out of travel (clicks) at 0.386 V with Offset at 0 at that, but offset Bournes is also within a turn of Clicking as well
Are the 6.2v Z 's and those resistors Not allowing any higher bias ??
Device Temp is at 27 C after an hour.
Ohhh :headbash: Just realised that the Bulb tester gizmo shouldn't ?? be in circuit for this
Back to the meters to reset and try again 😱
The F6 should bias without any problem. Start with .500V and check heat sinks. I believe I went to about .700V but did not really hear any difference with the higher bias. I always use a 100W lightbulb with my current limiter with SS and 300W with tube builds.
It's Alive!
Without Tester Bulb in Circuit 😱
It biased /set up Foolishly easily.
0.55v.. 0.00v offset.. devices at 45C, Heatsink at 40C Seems (so far) as rock steady
Really it's embarrassingly simple.. Once one knows how
All that's missing Now is to button up and attach Speakers
Thanks 😱
Tested with a pair of DIY Mark Audio full rangers (albeit with tweets) which to be honest, never did please me.
Sounded a helluvalot better on the F6 than ever before tho.
Sounds seemed a bit thinnish on start up, good detail and presence however. Interestingly after a half hour or more of use... sounds became fuller, deeper and clearer.
Quite Nice when fully warmed up, actually.
I'm liking it 😀
Clearly this isn't going to be an Instant on/ready to use Amp.
Small issue with my Leds. I fitted 3mm ones to 1/32" holes in the front panel. Still Too Bright, especially the green PS ones.
A wee trimmer pot fitted inline to dial in the brightness.. perhaps?
A passable idea? if so, any quick suggestions for a trimmer value ?
Testing my Tannoys .. tomorrow 🙂
Hi Guys,
I've been enjoying my F6 for several months now, but when I switched it on after 30 - 40 seconds a low hum, lower that a ground loop comes up under the music. Before it was always dead quiet. It still plays music but with a deep hum. I opened it up today to take a look and I found R4 on the left channel fried, everything else looks fine, and all looks good on the right channel. I had used 1/4 w MF resistors in this position. I'm going to order some replacement resistors 1/2w MF this time, but before I do is there anything else I ought to consider replacing ?
Thanks,
Paul
