The offset and bias will drift with warm up or even when you put on the chassis cover; it's best to readjust it over a period of time.
Ran it untill stable, powered down, hooked up B-1 and speakers power up, and it makes music. Thank to everyone and especially Peter.
Russellc
Russellc
Peter, what is the status of the F-5 boards? If there are any, I'll be needing a pair in a couple of weeks. I remember you saying something about getting low. Any plans to order more?
Russellc
Russellc
Yes, its working, I'm down to 5 Mv, I think I can 0 it out. I wouldnt have expected the circuit to work like that, but I turn one up and the other down, the Mv on the output goes down and the two resistors measurements are the same, but low. Now to bias it up. Thanks for the time to school me here, much appreciated. I can pay now if its getting to the end. Are the power supply boards still plentiful? I know they are not specifically for the F-5, so I assume you'll be kepping these around?
Thanks for info,
Russellc
Say can you guys give me an idea about what is "normal" in terms of drift in the offset and bias of the F-5? Mine's just breaking in and if I set it at .59 and 0 mv and let it play for a few hours and remeasure, it seems to go up to about 15mv-(at first 25 mv) and bias at .61. Heat sinks handle it well, can touch indefinitely. After a long listen last night, it again drifted up to 14-15 mv and .60-.61 offset. I reset to .59 and 0-1 mv and powered down. This morning I turned it back on, let it set for about an hour with no music, and had 5 mv off set and .58-.59 bias. Is this normal?
Thanks for the input,
Russellc
Russellc
But AFAIK, thermistors should keep it more stable, shouldn't they?I would say that's fine. Probably more so with Thermistors than without.
I did some measurements how bias stabilizes in my amps (without thermistors): http://www.diyaudio.com/forums/group-buys/140306-f5-pcb-group-buy-15.html#post1935126
I think the thermistors help National Semi's keep a little more stable with thermistors, but importantly allow it to bias up quickly.
With no thermistors, and IRF's or Toshibas, I see rock solid offset (no drifting). It does take longer to warm up, but I say doesn't make much difference in sound after 30 minutes.
I find that there is a big variance between summer and winter bias and offset levels without thermistors. Basically, once you set the bias without thermistors, the amp likes to remain at the same ambient conditions that you had when you set the bias.
Else the bias goes up when the ambient temps increase, and down in winter or monsoon seasons. Thermistors do keep this more stable and reduce the amount of fiddling one has to do to keep everything nice and happy, but what good is an amp if you don't have to open up the hood once in a while anyway? And in my case, it's pretty much unusable with the 35 degree + room temperatures of a tropical summer, so for me it's a winter amp only.
However, omitting the thermistors results in much more stable bias and offset over a short-term period - personally speaking. I checked over a period of about ten days and the bias did not move at all from where I set it, and the offset was <2mV on each channel. Picture changes when the seasons change though, but I prefer that to a shifting bias point that is almost impossible to pin down with the default configuration. I end up having to keep the amp on for an hour or so to get bias to the exact point I want it at, which is fine as it is playing music at the time 🙂
Peter, in post 300 you said once it reached .659 "It was steady as a rock."
Is it OK to leave at this higher than .59 bias point? Or did you scale it back down?
thanks,
Russellc
Can I still order a set of your PSU and F5 boards?
I think I got his last set of F-5 boards. I dont know if there are plans to have more made. Peter told me he had the PS boards still. Will there be more Peter?
Russellc
- Group Buys
- F5 pcb group buy...
