Exploding output fets SPL Dynamics D8s
Connect a 10v Zener between the source (anode) and the gate (striped end),
Do you have any fast recovery diodes? Something like a 1n4148 may work.
How fast do the input and output voltages for the 7812 regulator for the 21844s drop, in relation to the remote being removed. Check this in differential mode with probe 2 on the negative rail.
For clarification, remove the 10v zener?
Do you mean D52 from the attached diagram instead of D22? I can't find D22
The jfet needs to have positive voltage (relative to its source) to be switched off. 0v to switch on. The 12v regulator voltage wasn't dropping quickly enough.
The jfet has a limited voltage that it can withstand at its gate. The Zener is there to protect it. It will always remain connected across the jfet gate and source.
The 1N4148 is going to supply voltage from the transformer to the gate of the jfet via the resistor. This voltage will drop much quicker because there is no capacitor when the PS switches off
It's D22 on the AQ20 diagram (may be different in your amp). There are 4 diodes (including D22) that are connected to a dedicated winding on the power transformer. The diodes are sometimes near the transformer and sometimes near the 7812.
Thanks for the explaination 🙂
This make the working of Jfet more clear.
You were right, D22 (4 diodes) were hidden near the transformers under a load of transformer windings.
Currently, the output does not switch. There is no potential difference between D22 anode and Jfet Source
0.15 volt between Gate and Source
0 volt between D22 anode and Source
I connected the 10k resistor and 1n4148 to D23 cathode, now it oscillates.
It barely dumps rail voltage now anymore.
The only dump is 14v rail voltage idle, to 13.22v after powering off
This is likely not going to be a viable solution due to requiring a bit too complex but it may lead to a better solution.
0.15v may be a meter error.
Try paralleling a very small capacitor (0.001uF) across the Zener. Does that prevent any rail dumping?
Are you sure that the rails didn't drop approximately the same when the driver ICs were disabled?
Yes 🙂
About the output fets, it probably still blows the fets.
The fets blew up twice with powerup on full rail voltage.
The output fets directly starts oscillating as soon as the remote is applied.
It does not wait until full rail voltage is reached.
