Explendid amplifier designed by Michael Bittner, our MikeB
abaout sound quality for couples mj 15004/15003 and 2sk170
Hi, Mike
I am very interested to build your masterpiece. :up:
I have old stock pairs of mj 15004/15003 and 2sk170, can I use to get good sound quality?. Can you recommend it.
How about the sound quality would I be, when using the pair of mj 15004/3.
I plan to build two pairs for each channel, how to setup the bias current of each pair to get the best sound quality?.
I would use a circuit like rudi ratlos TO3 pcb.
Many thanks for the response.
i'm noob , sorry for my english. 😱 😎
First of all, u should have good speakers that cost around Rs.50000 a pair and above, to judge whether an amp/transistors sound good... and there r so many other things. These intricacies r not needed now.
If noob, then u should read and construct the low TIM amp at
Leach Amp Plans - Part 1
The site very nicely explains the construction and the difficulties are also sorted out.
If u have any difficulties, ask for them in a separate thread of your own.
Gajanan Phadte
Simple modification. The operational amplifier increases the useful signal 0dB, 30dB signal the error. In conclusion, the bias decreases 20dB
