Explendid amplifier designed by Michael Bittner, our MikeB
sajti said:
Hi Mike,
I think, that PNPs have higher B, than NPNs. And at the beginning there was not too much high voltage PNP transistors to use as VAS. So everybody used PNP input, and NPN for VAS...
sajti
Ah, a relict from old days ?
no.
It is much more likely that PNP are chosen for the input LTP, due to their reputation for lower noise.
Mike,
your recollection of -12mV (or -27mV) is not wrong. It came from as built measurement, see post2515.
phew bias touchy with 1k pot.... while 24mv across top of the two 0.22 resistors targeted and read that below 20mA means crossover distortion, how much can it be increased to?
Without installing a pot, whats prefered way to make less sensitive to my source which has it's own output level capability but sym's 32db a little jumpy in my application, especially when use my higher efficiency speakers. Get tempted to touch 2k - 22k input side.
Lastly, how low can voltage rails be before have problems?
Hi traw,
The bias control was changed to a 500R control. I find that just about right.
Your rails should be around 35VDC with this design. Higher voltages will require more output transistors to maintain safety margin, different Vas and some other transistors. Add some heatsinks to the Vas as well.
There are other threads on the SymAsym that you should pick through. Other members have gone to higher power by modifying the design. I find the original SymAsym to be very good.
-Chris
currently running on 36-37volts... curious if would encounter problems at 33 volts, maybe even 32.
will changing 2k/22k input to 10k/47k have bad impact? (like built in voltage divider attenuation).
yes, very good sounding amplifier one of the clearest and open i've heard.
Hi traw,
No, the amp works great "down there".
Yes. Don't play with that. It will affect the DC offset for sure. To correct the offset you will need to mess with the feedback network. That's where everything will go sideways on you.
-Chris
Which board did you build? If you've built the 5.3, you have the option to install r16/19 and change the feedbackdivider to reduce gain.
Mike
I see Pavel used a XLR in his review : “with XLR connectors, pin 2 live input, pin 3 input GND, pin 1 Shield.”
Is balanced input possible for SymAsym5-3? With or without modifications?
Is there somewhere a schematic with XLR connection?
Thanks, Laurent
PS : Is it possible to print every 330 pages of this Thread or only one page by one ?
An idea to improve the SymAsym VAS by buffering, distortion is about 10x lower. If someone else has already recommended, then I am sorry, I do not have enough time to follow the discussion.
How is stability? I tried a triple darlington version but discarded it...
Which distortions are lower? 2nd harmonic or the higher ones?
(i have no spice installed yet on my new computer)
Yes, higher power for symasym is difficult because of quite low current in vas, that's the price for using cheap and available to92 here.
Mike
Mike
Hi Mike,
2nd, 3rd, and the higher order content as well.
Regarding stability - you can see one capacitor added in the second diff stage. Value of Cfb changed.
Let´s wait for the built modification, this would say more.
