data said:Hay, Bill...
I measured the transformers like you suggested, and I got a reading of 2.5Mohms in one direction and .47Mohms in the other direction 😕
Oooh, that cant be right. You mean one winding reads 2.5 megohms and the other reads .47 megohms? I can't even imagine how much wire that would take to wind on a core. Check your meter by measuring some known resistances, then check your connections and try again.
I cant think of any other explanation that would make sense, unless you dont have the right pair of wires for each winding.
Bill
Yeah, Bill
Has me stumped a little...
there are two other pairs of wires on each that are connected to one another, but I have no idea on what should be connected to what 😕
If Joe R, who these came, from would respond to my requests for help (specs) things would be much better.
Sumlink ST-DV709 Digtal Audio isolation transformer
The new board does not have the Sumlink ST-DV709 Digtal Audio isolation transformer, is that going to be an issue I read way back in the thread that it basically renders the S/PDIF inputs weak, I have contacted the seller and she will supply one for $30!! but I can pick them up for under $10 delivered.
what does it do ? will I need it and if so how and where does it go on the new board.
And is there better ones.
Checked all the connections on these and they are unsuitable for this application, looks like I need some transformers again 🙄
Did anybody try the EDCOR transformers? how are they?
data said:Checked all the connections on these and they are unsuitable for this application, looks like I need some transformers again 🙄
I'm looking at these trannies as well, I contacted the company and its $13.50 shipping or two XSM's to Australia via USPS Flat Rate, not sure if they are any good though.
Bill Fuss said:
That's great. You can try doubling the primary Rs to around 500 and halving the cap to around 1000pf. Some, including me, found slightly fuller bass.
Bill
Got those UTC A-20 transformers recently (but cannot try them right now): That's fine for the RC at the primary. Unfortunately, I don't have any scope to measure the right set-up at the secondary.
I don't have any A20s, but if they are 500 or 600 ohm 1/1 trafos suitable for output use, then there really is no "right" secondary setup in that they do not need a load to work properly, contrary to some people's belief. I have read up on the subject since starting my experimentations by going to various manufacturer's websites.
Incidentally, the primary filter arrangement is for the chip output and really has no influence on trafo operation.
Feel free to use your ears for the sole judgement.
Best, Bill
utc a-20
Yes Bill, they're output transformers 1/1 and can be set at 500-333-200-125-50 / idem for sec. Since I can "play" with these values that's what I'm going to do. And you're probably right about the need for stuff at the secondary. But even I'm no expert I heard the "ringing effect" ( if it's significant) can be improved.
A 1k resistor in series with a .001 cap across the outputs will give you a good starting point.😉
Bill
Bill
Re: UTC A-20
I have the factory printed specs for the UTC-20 here on my desk. On there it is listed as an INPUT transformer, Mixing-Matching Primary, 50,125/150, 200/250,333, 500/600 also marked "high electrostatic shielding"
(secondary is the same). +-2db 10-50,000.
crazyfrog said:Yes Bill, they're output transformers 1/1 .........
Does it list a max dbm or dbv number for them. They are apparently the "swiss army knife" of the older broadcast equipment, I've seen them used on both ends of equipment.
Don't get stuck on the impedance numbers, the real impedance is related directly to the load they see. In a 1/1 setup the load on the secondary is reflected through the core to the primary. The rating, be it 150 or 600 is the max load that the transformer will operate into with the rated distortion numbers. An easier load such as 10k gives it a lot more headroom.
Bill Fuss said:Does it list a max dbm or dbv number for them. They are apparently the "swiss army knife" of the older broadcast equipment, I've seen them used on both ends of equipment.
dbm= +15
MW = 30
Primary R = 64 Ohm
I will try and scan the list as it has similar specs for most of the UTC A series Tx.
Re: utc a-20
I have a pair of UTC HA-108 which have the same specs as A-20. After many tryings, I use the 500 ohms primary and secondary taps. With a scope, I looked at the square waves and can tell you that the UTC I have don't ring a lot so I tried many secondary loads. The best square waves I got were near 680 ohms at the secondary.
With that setup, the sound is simply marvelous. Authority with unagressive sound. The battle with the best transformers is between the Lundahl LL1690 and the UTC HA-108. HA-108 are beefy and are terrific in the bass. As I have to decide which one is the best I could say that the Lundahl are champion for unagressive detailed sound but the UTC HA-108 wins in the bass region and with a huge soundstage. I will surely keep both UTC and Lundahls. The Tamura is still one of the best for the price.
crazyfrog said:Yes Bill, they're output transformers 1/1 and can be set at 500-333-200-125-50 / idem for sec. Since I can "play" with these values that's what I'm going to do. And you're probably right about the need for stuff at the secondary. But even I'm no expert I heard the "ringing effect" ( if it's significant) can be improved.
brianco said:
dbm= +15
MW = 30
Primary R = 64 Ohm
That's around 4V RMS into a 500 ohm load so you have tons of headroom.
The A22s I bought were Real NOS so I'm running them in for a while, but they lack nothing except half of the bottom octave. Maybe they'll get better, maybe not, time will tell. They didn't ring much either. They immediately kicked the cheap Jensen JT-123s butts in every respect.
Re: Re: utc a-20
Thanks for the info. Did you just put a 1nF cap (or so) between the 680Rs or is it a more complex setup (like the LL1690)? Is your RC at the primary the same than the Lundhal?
Many thanks for advice.
My UTCs have reached Scotland - I have had to pay about $30 import charges!!
There are probably many kicking around here neglected and not likely to be used again - but it is the finding of them!!!! That is where the great on line auctioneer is indispensable!!
What is interesting is that the UTC a-20 Txs on my factory specs, starts to roll off at at around 30+K with -1Db at 100K. THat is pretty good! Some others such as the A-10 start downward as low as 7K with -2Db at 20K.
I will scan these and post the graphs and the specs later today - they may help in choice making for those in search of such things.
Re: Re: Re: utc a-20
On the transformer primary, I just use 220 ohms Allen Bradley carbon composition resistors (old stuff) The cap I use is 7 nF (7000 pF)
This gives a low pass filter of 51.68 khz at -3 db
Bad news with this dac
I looked at the specs of the USB receiver chip they use in this dac. The PCM 2707 can not go beyond 48 khz
24/96 and 24/192 can be used only with S/PDIF inputs
low pass filter
I'm a little puzzled...When Bill write:
"You can try doubling the primary Rs to around 500 and halving the cap to around 1000pf. Some, including me, found slightly fuller bass"
That makes a 159 kHz filter.
But Legarem uses a different setup:
"On the transformer primary, I just use 220 ohms Allen Bradley carbon composition resistors (old stuff) The cap I use is 7 nF (7000 pF)
This gives a low pass filter of 51.68 khz at -3 db"
We're talking about the same DAC here...
- Digital Line Level
- Experience with this DIY DAC ?
