Driver chips for BPA300 amplifier
alex i live in macon, georgia the heart of the south in the u.s.a. however, i truly envy your chinese sources. most of the places you are able to purchase from will not return my email, in the instances that i can translate there webpage, making purchasing very difficult. i believe you could develop a rather nice semi-profitable venture as a go between. i for one would gladly pay for your services. not only do these sites offer hardware they have some really nice designs.
i am still trying to get this input impedance thing figured out. either transformer or buffer or ths4131 i do not know how to choose and match impedances for correct design. i have the major parts all laid out except for the math part. thanks
balanced circuit matching
using Alexcd posting as an example.
the match pairs are
r1&2
r3&4
r5&6
r7&8
r9&10
and the source coming into ain1 & ain3 must also be matched to similar accuracy.
See Walt Jung for an explanation.
He also recommends the receive end should have high Zin to maximise rejection ratios. Non-inverting can achieve this much better than the inverting buffers shown.
AndrewT said:
What's the source? Will the receiver benefit from a bit of filtering?
Better to join the two 1M together and build it truly balanced.
Or just copy Jung.
alexcd said:
My source is a run of the mill HT receiver. I would like this to work for anyone with passive preamps as well.
I would really appreciate a link to Jung's circuit or thread.
both your proposal involve interconnects.
I suggest you add some RF filtering.
I gave you the link a few posts back.
andrew if i installed this circuit in my passive preamp would it not work as a preamp standalone. i could effectively balance every signal coming out of the preamp. would this necessitate the use of a receiver in the amp. do you feel confident in your numbers enough for me to copy and try.
i have also been looking at the linear technology equivalent to these differential chips. they have some nice application notes and i believe jung helped with some of the circuits.
I have no confidence in any numbers I invent.
They always need to be proved.
Go and consult Jung.
A balanced output from a source will require a balanced receiver at the other end. Otherwise you are throwing away the small advantage, if any, of adopting balanced through your pre-amp.
