diyAB Amp The "Honey Badger" build thread
Joined 2016
Ok So I have made this winding tool to wind these inductors.
Lets see how it goes
Hey guys! Just checking in!
After succesfully building the Mains Bulb tester, and after disassembling the amp, I have found the problem for the fuse blowing!
I should add, this mains bulb testing is really great, since I could "see" in which module the problem might be.
The V- fuses blew simply because of the poor speaker connector insertion in the test speakers. They were connecting to each other, thus the shorting problem.
Using the MBT, I have found that my 1000VA toroidal became dead silent. Before, it was making some buzzing noise... Can you help me how to get rid of that I dont want to have the MBT always connected, but want to get rid of that buzz..
I attached a sound clip of the transformer buzz without MBT.
Sound Clip: Transformer Buzz without MBT
Also, I was trying several connections to reduce the noise problem which was happenning with me. Don't know why, but I found out that if I connect the signal ground with the speaker ground, my speakers stop emitting the strange noise which was initially my problem. Good, but can someone tell me why?
I attached a sound clip of the signal gnd connecting to speaker gnd before after comparison
Sound clip: Speaker gnd to signal gnd before/after
Thanks for the help guys!
Joined 2016
Ok. I found the problem. That web site is not calculating the impedance correctly for some reason. Or the formula is not for these types of coils / inductors.
I used 2 other sources and got answers that match my oscilloscope results.
I also manually caculated it using there supplied forumlas.
I current have 1.692uH
So from my findings I still need to make the coil a little shorter. But at least I can do a sanity check with a formula that works.
I hope this help someone else.
I will keep working on this until I get the correct result.
Cheers.
Sent from my SM-G920I using Tapatalk
