DIYA store "Wolverine" (Son of Badger) .... suggestions ??
Just think , all that copper and caps in JJS's slewmaster could be replaced with this ...
Reactions: Hipocrates
I meant speakers
Hi, OS...
You might recall about 3 years ago that I asked you what you thought of my using the Honey Badger with 4 ohm nominal loads. The speakers are Infinity RS2.5, which are a relatively difficult load. Your response was essentially "absolutely no"... You recommended that I move on to the Wolverine project, which was in the design phase. The result of that discussion is a quad Wolverine, which I listen to every day. I've been beating on it for close to 2 years now and it never disappoints. This led to JJS and I to explore some further "amp porn" as you say, and the 6-pair/8-pair beast was born. We're not done... more "porn" to come.
If you can't wait ... go for it. In fact , I would like to look at the hypex for inspiration. But , in the end MY SMPS will be the best. AND , everybody will
get to play with mini toroids and baby EI cores (DIY rules) !!! We will get anal over the finer points of the circuit and make the cleanest quietest one to be had.
PS - Hypex is Rubycon capped 3X low esr at each output ... looks like the full bridge self resonant standard issue. Adressable , as well. NICE !!
Reactions: hotdarkmatter
